Just wondering if anyone had specs on hepolite piston to cylinder clearance, valve to guide clearance, valve guide to head clearance,stem protrusion in guide,and valve spring height.just opened up my motor and everything looked pretty good until i popped off the valve springs.three new +.002 guides and one old guide which happened to be the left exhaust .i was having issues with oil pouring out of the left exhaust port.The valve to guide clearance seemed excessive on all of them.Quick check with small hole gauge and mic appears to be around .015.Clearance is also greater at top quarter inch of guide.just looking for all the specs i would need to rebuild head and fit old pistons with new rings. Thanks
