Hello all,
Ive been trying to diagnose if it is my stator or regulator that is causing my bike not to charge.
Here is what i have tested so far, I've been trying to read the manual but electrics have never been my thing.
With the bike running i unplug the stator to regulator connector and put my multimeter on AC into the stator connector terminals, with the bike at idle i get around 15 volts and upwards of 40 when i rev her up.
The part i am confused with is the test where they say to switch over to ohms and place the leads on the stator terminal. With my multi-meter on the 200 ohms setting i get 3.3. The manual says it should read .2-.4, did i have my meter on the wrong setting or is my stator bad?
Also if it is the stator do i need the clutch tool to do this job?
