when reassembling the fork last night i noticed that the shaft that bolts to the inside/bottom of the lower leg rides kinda loosely up & down in the assembly that bolts into the upper tube. is that ok? the shafts seem worn but if its no big deal, i wont sweat it. just wondering if all the oil will just blow through the loose fit instead of the damping valve. im about 200lbs & running 10wt oil.
