I've had this 71 TR6R for a little over a year now. Just finished with the engine. So i figured I'd post some pictures of the project. Planning on welding a FMW hardtail on the original OIF.
The engine got fresh gaskets and seals of course. Had the crank polished. Fresh rod bearings. Wes White hooked the head up with some aluminum spigots. I lapped the valves in by hand. Replaced the wrist pin bushings. The cylinders had some pitting; so I got some .060 Emgo pistons and had the jug bored. Had to replace the primary chain and the clutch fibers.
I'm planning on running the stock points for now with a harley coil. Got a podtronics regulator / battery eliminator.
I hope to have it on the road by Spring.
