1 - 7 of 7 Posts
I have a set of S&S alt. Shovel cases and I want to use a side oiler cone (cause I have it) on them.
If I weld up the drain behind the bush, use an end oiler bush and
slot the feed hole to feed from the top hole on the crankcases, is there anything else I am missing to stop me using it?
Thanks
thanks, this is the motor with the evo rods (I asked Q about) and T&O 4 1/2' wheels with stock bore.
Any opinions on an 84''er
Looking forward to cranking it up!!
1 - 7 of 7 Posts
