City | Chico |
State | Ca. |
Price | $1800.. |
1966 BSA A65 Custom Project...Barn fresh ...just rescued from a 30+ year sleep in a walnut orchard barn in Northern California..matching frame and engine numbers...True mileage is unknown..Hardtailed the old way,using the original swing-arm.....many period original parts including Arces alloy triple trees with later sliders ...Flat track bars..Original Bates headlight ..2x19 Jones rim laced to the original front brake and hub assembly..Hummer fuel tank with offset filler neck..which has been moulded into the frame....Octagon oil tank...16x3" rear rim laced to the original hub and drum..(chrome on the rim is flaking).. 5" flat rear fender ...original header pipes with upswept shortys..Motor turns and shifts through the gears..Top end is loose on the motor and needs the cylinders honed,pistons fitted and a valve job done..Wil also need wiring,seat,tailight and some hardware..Comes with clear,original California title...signed off by the original owner awaiting transfer into the new owners name..Very cool,period piece that will only become more collectable with time...Nice winter project...SOLD
