Looking for info on how much compression one can run on these old things (Triumph/BSA) before the use of pump premium is no longer acceptable.
I have the means to correctly cc the chambers and piston domes. Also access to a mill should I have to taylor the piston dome to what compression I want to run.
I'm assembling an S&S 113 now for a bike, these run 10-10.5 to 1. The chambers do have a quench area though and flat tops. I know the hemi chambers, such as Triumph/BSA can be less forgiving.
Any real experienced input would be appreciated.
thanks
thanks
