Okay guys, I finally have another update. I have been super busy with working on other people's bikes lately, so the sporty has been neglected. I have the cases ready to be split, but found some suprises tonight when I pulled the trans. The cases need some welding, and some one has already done some welding in the past. This bike has suffered a tranny blowout at one time...... The trans was full of aluminum shavings, and the sprocket nut was only finger tight. These are all reasons why I prefer to tear down these old motors to have a look before I trust my life riding on it.
welded up section of case.
this whole rear section of the primary has been welded back together. Looks like some type of case sealer over the welded areas?
looks like the gears were grinding on the cases, which would be where all the aluminum shavings were from.....
almost every ironhead has a cracked primary cover mount hole. There is also a crack where this area meets the main case that I will need to weld. look closely.
Do most of you guys remove this valve and install a pipe plug?
It is a good thing I have been practicing up my aluminum tig skills in the past couple of weeks. It looks like they will come in handy on whipping this motor back into shape. lol. Hopefully I will have the cases split later this week, if I can find the time.......
