1 - 4 of 4 Posts
Didn't knucks still have a centrifugally controlled oil pump by-pass under the cover? I know it was deleted and a special block off plate and gasket was installed later, which WILL work with earlier pumps (and was considered by the factory to be an update). If that's the case, he can run it with out rotator if he uses the plate and gasket, which are still available.
-Kuda
'49 panchop
Yes, later Knuckes('41-'47 and '48 Pans) did have the rotor "governor" to bypass excess pressure. But it never had any kind of spring in the mechanism.
Robbie
1 - 4 of 4 Posts
