1 - 9 of 9 Posts
New here but i've been on HAMB quite a while everyone there said i should post some of this here
The bike already runs but why not make it faster. sorry i dont have pics of the bike now it's in storage but it is black with old style flames and a XA springer
Check out the factory porting on the KR racing cylinders That is a '40 WL bottom end i'm planning to come up with a set of KH wheels and with the overbore that will make it around 56 or 57 cubes
do they(kmodel heads/barrels) bolt on to the 45 lower end or is there more to it?
Rich,
Thanks for posting the Mike Williams bike....definitely one of my favorite bikes of all time. If it is still around, I would love to see it!
Hank
Shaggy said:
Almost, one hole is off Not Quite to valvetrain yet Not sure on the differences between K and KR either valve and oil wise
Looking good! As mentioned next door at the HAMB, I've been collecting K/KH cylinders & heads (mostly brutally used & barely salvagable) in the hopes of cobbling together a decent pair for an eventual WL/KH build.
If you don't have Panic's books from Victory library, you'll likely find loads of good info you may/may not be aware of in there re: K top-end on a W bottom. Loads of other good 45 info in there as well.
For now, need to switch back to chain primary & get my gearing in a happier zone on my stocker! ;) The K top-end will have to wait....
Discussion Starter · #9 ·
My cylinders are barely salvageable too there .050 Over but i found out why the kr cylinders are a lot of times that bad Ama would only allow .050 over when they were racing so some of the big unraceable ones are left
1 - 9 of 9 Posts
