thanks.. I sent you a pm.. my gages look like the one in the link above that shades34 posted..My 77 had both instruments in stamped holders that mounted to the fork top nuts. Mine had NVH logos and I expect your's would've as well. I may have one if you need it but I'd have to dig a bit to be sure....![]()
NVH ? or NVTMy 77 had both instruments in stamped holders that mounted to the fork top nuts. Mine had NVH logos and I expect your's would've as well. I may have one if you need it but I'd have to dig a bit to be sure....![]()
not sure what NVH or NVT meansNVH ? or NVT
1976 is a year model not a model descriptor, the engine and frame number will tell the whole story, probably pretty rare now, but triumph & norton shipped many variants of military and police models across the British commonwealth, many of these had different spec or special instruments.
Short answer a "bonneville" should have a speedometer and tachometer, but back when you could order on the factory many variations were possible.
oh.. okay then mine is NVT.. The bike came without a tach or speedo.. It was mfg'd in December '76. I already got a NVT speedo coming so thats what I want the tach to be.The blue white logo is NVT (Norton Villiers Triumph) if you have the number at the bottom of the speedo I can tell you the matching tach.
The funny part is in 76 its 50/50 could be a smiths, or an Italian Veglia.
The Veglias started sometime in the 1979 production run. They used Smiths on early 79s and Veglia when they ran out of Smiths. By 1976 the Meriden co-op was independant of NVT. The co-op manufactured the motorcycles and NVT distributed them as per terms of their settlement with the co-op. Check out this website for original ads and brochures of Triumph motorcyles: http://www.classicbike.biz/The funny part is in 76 its 50/50 could be a smiths, or an Italian Veglia.
Cool.. The other Triumph I owned was this '71..tore it all apart and rebuild it caveman style in my florida room.. rattle can paint job.. I bought a 73 and put the disc's on the '71 (see the go cart rear master cylinder bolted on the frame??I own a 79 T140E that was my fathers, I have a pic somewhere, 79 T140 Bonneville with Italian clocks & German carbs, 79 Ducatti with smiths clocks, Beemer airhead with same carbs as my factory Bonny
its all good
Hey, thanks.. missed your post while I was posting!The Veglias started sometime in the 1979 production run. They used Smiths on early 79s and Veglia when they ran out of Smiths. By 1976 the Meriden co-op was independant of NVT. The co-op manufactured the motorcycles and NVT distributed them as per terms of their settlement with the co-op. Check out this website for original ads and brochures of Triumph motorcyles: http://www.classicbike.biz/
Scott
My mistake, I know someone who owns a 77 silver jubilee with Veglia clocks on it, I always assumed it was nut and bolt correct, obviously it has had instruments changed at some stage, maybe he has the smiths clocks stashed away somewhere.The Veglias started sometime in the 1979 production run.
Scott
I know my one owner '79 Special had the Veglias so that is probably correct.. maybe a transition year and the still used Smiths on the standards??I too have a 79' Special, which is a T 140 D it has Veglia Guages.
I also have a 79' T140 E standard Bonneville it has Smiths .
I often wondered which or if both were correct to model.
