1 - 3 of 3 Posts
Had gearbox out during sludge trap procedure and now it seems to only wanna go into 1st N 2nd...feels like the pawls aren't grabbing anything above 2nd. I have set the thing twice now to no avail and before putting the access cover back on, I could shift it through all gears. I know it's gotta be something simple, what am I missing??
Did you use a gasket for the outer cover? I had one once that was so close to being out of whack that it HAD to have a gasket or the shifter wouldn't catch right.
Also are you bench testing this or is everything else already back together? Make sure you have hi gear nut on and torqued properly as well as make sure your kicker stuff is correct.
everything back together, gasket on outer cover...same as when it came apart though. double checked everything since this is the first 5 speed I have gotten into in awhile. Just don't see that many of them.
1 - 3 of 3 Posts
