1 - 11 of 11 Posts
How much fork oil is the proper amount for a set of 1949 Panhead forks? The the tubes are 4+ over, and the lowers are stock with stock springs. OEM HD.
If fresh its like 7 oz per. If just changing it, 6.5 if memory serves.
the inefficiency with the original fork assembly has lent it self to wanting regular 30W lawn mower engine oil - not what the MOCO has in the book been using that for as long as i can remember
+2 on the 30wt. works great. fyi, when a fork has longer tubes installed it doesn't change the amount of fork oil required. it still just needs enough to keep the damper covered.
I measure the height with the fork collapsed and springs removed. The captured air above the oil adds a little to bottoming resistance on the last third of the stroke. So if ya use 100MM/4 inches and it bottoms harsh add 5mm/1/4 inch at a time until it gently bottoms or stops under normal circumstances. If you go from a stock length fork to a +4" fork measure before swapping and use the same measurement-which requires more oil by volume for the longer tubes.
Oh and definitely use the 30 weight on the older forks. They need the viscosity.
Ok.....I'm not that familiar with hydraulic frontends. Springers mostly.
So 'splain why the 30wt. What is the difference between that and the OE fork oil? Seriously, I want to know.
The damping assembly for the 48-71 (oops 49-77) fork was designed prior to dedicated fork oil existed so works best with what it was designed for. Which is straight 30 wt motor oil.
Moderator
Thicker oil slows has a harder time moving through the damping orifice, leading to firmer front end feel.
i think it rides much smoother with the 30w than any fork oil - it becomes like a slow moving shock not like HD shocks that bounces
1 - 11 of 11 Posts
