1 - 5 of 5 Posts
Just curious went to mount the wheel ( 5/8 axle ) on my SB&F girder and come to find the axle holes are 17mm. This Brit or Japanese ?? Common ?
Someone may have drilled them to 17mm (.669") in order to run a Japanese/Metric wheel. You may be able to find bearings with the OD to fit your hub, but with a 17mm bore.
Bob
When I shortened my SB&F girder, I machined new ends with a 3/4" hole. That gives me the option to run different diameter axles by sleeving the hole for anything under 3/4".
Bob
1 - 5 of 5 Posts
