Any tips for cleaning cast aluminum? - Page 3 - The Jockey Journal Board
Old 07-01-2008, 05:04 PM   #41
spinedoc
spinedoc's Avatar
Default Re: cleaning aluminum cases without disassembly.....any ideas??
I just used some aircraft stripper to get the paint off a set of cases. It worked great. Brushed it on, let it sit, scrubbed it off with a solvent brush. Be careful though, I also took some paint off my bike lift too when I spilled it on it.
spinedoc is offline   Reply With Quote
Old 07-01-2008, 05:36 PM   #42
jscoma47
be careful around powder coating also,the aircraft stripper WILL remove it.
UNION PROUD! IUOE LOCAL 138!
Road Lords CC
jscoma47 is offline   Reply With Quote
Old 07-01-2008, 06:27 PM   #43
Fredo
Brake cleaner first, then soap water and a few good stiff bristle brushes. Rinse and you're done. The 99 cent store is your freind in times like these. If you get lucky you can even find brake cleaner there.
Fredo is offline   Reply With Quote
Old 07-02-2008, 12:28 AM   #44
63CadGuy
Make sure the room is well vented, this shit with give you a hell of a model car glue buzz if you're not careful!
63CadGuy is offline   Reply With Quote
Old 10-22-2008, 11:27 PM   #45
Gas House Gorilla
Gas House Gorilla's Avatar
Default Re: Cleaning cast alluminum?
How about cleaning cast iron? Without blasting.
Gas House Gorilla is offline   Reply With Quote
Old 10-22-2008, 11:39 PM   #46
Lurkingclass
Lurkingclass's Avatar
Speaking from experiece on this one, the oven cleaner does not work. I left some aluminum Triumph parts in some purple cleaning stuff that turned them black, so I followed some JJ advice and tried the oven cleaner which did nothing- even after a few hours. +1 on the walnut shell blasting though.
Lurkingclass is offline   Reply With Quote
Old 10-23-2008, 12:01 AM   #47
front st cycle
front st cycle's Avatar
Originally Posted by Hazzard View Post
Aluminum wheel cleaner, the etching kind. Napa carries it.
seems to work well on al.
front st cycle is offline   Reply With Quote
Old 10-23-2008, 12:53 AM   #48
dandruff
dandruff's Avatar
Aluminum wheel cleaner works great, oven cleaner DOES NOT work on aluminum, it has lye in it which causes aluminum to turn black. Soda blasting would be best, or walnut shell second. I've had good results with Bon Ami® cleaner and a stiff nylon brush, the sink will get clean after too.
dandruff is offline   Reply With Quote
Old 10-23-2008, 05:44 AM   #49
Troy Fab
Troy Fab's Avatar
Anybody here do soda blasting or walnut shell blasting as a service?
Troy Fab is offline   Reply With Quote
Old 03-26-2009, 03:06 PM   #50
chopperkid13
chopperkid13's Avatar
Send a message via AIM to chopperkid13
Default Cleaning cases without etching or blackening
I have my bike torn apart and Im cleaning the head and the cases, trying to make them look like new before I rebuild. So for cast aluminum I have always used Brake cleaner or Orange Glo. I dont want to use anything that will etch, blacken or rough up the outside of the cases like Acid or sand / glass blasting. Any other recomendations? I always had my engines and heads hot tanked on my cars.. can the same process be used for aluminum?
So post all your cleaning, paint removing and degreasing tips and recipes. What even you use to keep you ride looking nice.
"It feels nothing like, how violent it looks from the outside. It's very serene." -Shinya Kimura.
thejadedandfaithless.tumblr.com -Choppers, chicks, hot rods, and other shit.
chopperkid13 is offline   Reply With Quote
Old 03-26-2009, 03:15 PM   #51
Gordo-uk
Gordo-uk's Avatar
Default Re: Cleaning cases without etching or blackening
Vapour blasting lokks like its called vapor blasting in the US
an example
http://www.andybuysbikes.com/Vapour%20blasting.htm
Gordo-uk is offline   Reply With Quote
Old 03-26-2009, 03:16 PM   #52
limlam
Iv always used mothers to clean my cases, cheap and effective, but iv never tried to get anything to any sort of show standard
limlam is offline   Reply With Quote
Old 03-26-2009, 05:05 PM   #53
Coco
Coco's Avatar
https://www.jockeyjournal.com/forum/s...8569&showall=1
https://www.jockeyjournal.com/forum/s...8774&showall=1
https://www.jockeyjournal.com/forum/s...aning+aluminum
Coco is offline   Reply With Quote
Old 03-26-2009, 05:44 PM   #54
R-U-Up2-It
R-U-Up2-It's Avatar
Send a message via Yahoo to R-U-Up2-It
You can HotTank aluminum my buddy owns a machine shop and does it all the time.I also used to repair the damn things for a company named JRI (nice machines) and everyone puts aluminun in them, Transmission shops, automotive shops even NASA.
Awww FUCK IT going to spend my cab money on MORE shots and just take the ambulance home!
http://img95.imageshack.us/img95/8686/ashleymekz2.jpg
[IMG]http
R-U-Up2-It is offline   Reply With Quote
Old 03-26-2009, 05:46 PM   #55
zedboy
zedboy's Avatar
an example
Vapour blasting, or whatever it's called in your neck of the woods is the way to go for bare alloy parts, WILL NOT remove chrome or other finishes from parts, can restore bits with good bearing/machined surfaces to usable condition and leave them with a natural cast looking finish.
zedboy is offline   Reply With Quote
Old 03-26-2009, 05:51 PM   #56
chopperkid13
Thanks for the info. I was looking into Vapor blasting but my cases are covered in over-spray, gasket sealant, oil and just about everything else.
Old 03-26-2009, 07:18 PM   #57
stumpworks
Wow, alot of info here, i just went to the auto parts store and bought some engine degreeser i think it was a cittrus based product. Spray it on let it set awhile and lightly hose it off, worked great. Now my engine was just oily and road grimey, not etched or anything like that but it did work very well. Also used a citrus based product on a old aluminum oil bag on the inside, rinse and repeat a few times, clean as a whistle.
stumpworks is offline   Reply With Quote
Old 03-26-2009, 07:31 PM   #58
RacerX13
RacerX13's Avatar
Yeh - that citrus stuff from Home Depot is good! Just used it last weekend and it worked like a charm.
RacerX13 is offline   Reply With Quote
Old 03-26-2009, 07:45 PM   #59
Hardball
Hardball's Avatar
PM TroyFab for the name of the guy he used to get his heads and cases done. Some kind of shot blasting process. I've NEVER seen such a clean job in my life.
--Bruce
Hardball is offline   Reply With Quote
Old 03-26-2009, 10:37 PM   #60
Troy Fab
Troy Fab's Avatar
Contact Don Hutchingson Cycle: http://www.triumphman.com/ and ask him about Tumbling your cases.
