Need help, show your remote front master cylinders - The Jockey Journal Board
Old 01-15-2012, 06:33 PM   #1
frankschap
frankschap's Avatar
Default Need help, show your remote front master cylinders
I started throwing around the idea of making a remote master cylinder for my front brakes that will mount int the tunnel of my sporty tank. It's mounted high so there is enuff room. I've got a couple options on hand including cutting up the stock one but I wanted to see what other ideas are out there. I've seen mini master cylinders used for gocarts and such, what are you guys using?? PLease post pics of what you've done!!
If at first you don't succeed, knock it over and hit it with a hammer.
frankschap is offline   Reply With Quote
Old 01-15-2012, 06:46 PM   #2
Loffer
Loffer's Avatar
Default Re: Need help, show your remote front master cylinders
saw this on the board and was checking it out , If i didnt have a springer i could live with this setup... Its pretty trick. looks like one of those tiny plastic metric MC's were you can use a little piece of tube for a resivoir..
Name:	remote master cylinder on narrow glide.jpg
Old 01-15-2012, 07:22 PM   #3
1ironhead
Too funny ... I just did a search a little bit ago and just now signed on to post the same topic.I'll be watching.Another member shot me a link to Fabricator Kevin.He has a nice one,but I'm gonna try to go a little smaller AND cheaper AND do it myself.
B Bob
1ironhead is offline   Reply With Quote
Old 01-15-2012, 10:00 PM   #4
panhead_pete
There is another recent thread on this.
Thanks
Pete
Old 01-15-2012, 10:14 PM   #5
Loffer
Loffer's Avatar
B Bob
F kevins is a massive hunk. Not of crap but steel. Its big.
Old 01-16-2012, 09:17 AM   #6
Skibo
Skibo's Avatar
Send a message via AIM to Skibo
You're insane! I understand you're not knocking his parts but come on. I've got it mounted underneath my frame backbone and between my split tanks. It is the cylinder and mount and that's it. I don't see how it could be any smaller and still function well enough that I'd trust it to work. Kevin's stuff is tip top.
Skibo is offline   Reply With Quote
Old 01-16-2012, 09:27 AM   #7
Dr. Benway
Mod Squad
Dr. Benway's Avatar
That's really interesting. I like that a lot.
Old 01-16-2012, 09:50 AM   #8
1ironhead
i went back and took another look at Kevin's remote.It looks top notch for sure.it just looks a little on the tall side to put in my tunnel.I'd have to get measurements,make a template to see if it fits.I'm sure it's worth every penny too,just not in MY budget at the moment.I haven't purchased anything from him,but did ALOT of looking at his stuff the past few years.
B Bob
Old 01-16-2012, 10:12 AM   #9
Skibo
Skibo's Avatar
When I was looking around for this setup I called him and asked for the measurements. I don't recall offhand what they were. Anyway, I then printed the picture out at 1:1 and glued it to some cardboard so I could play around with mounting locations.
Old 01-16-2012, 10:39 AM   #10
SixFingerJack
SixFingerJack's Avatar
If you get real desperate, you could always just buy one!
http://www.wwag.com/cgi-bin/WebObjects/WebSite.woa/wa/DirectAction?page=!41911
I know, I'll get my coat.......
XgJũK
SixFingerJack is offline   Reply With Quote
Old 01-16-2012, 10:54 AM   #11
Motor Mike
Shouldn't master cylinder reservoirs be on the top side? I thought those were all about gravity?
Motor Mike is offline   Reply With Quote
Old 01-16-2012, 11:01 AM   #12
Dr. Benway
Mod Squad
Dr. Benway's Avatar
Once the system is bled of air, it's a closed hydraulic system and you can orient them as you see fit. I think on a stock FL the rear m/c is lower than the slave.
Ooops, you mean "reservoir" specifically. Again, once the air is out and your reservoir seal is good I think it would be fine.
Old 01-16-2012, 11:11 AM   #13
sugarlou
sugarlou's Avatar
How about a proportioning valve and operate both front and rear offa the foot brake?
Heard its possible but the plumbing of brake line may prove challenging.
sugarlou is offline   Reply With Quote
Old 01-16-2012, 11:21 AM   #14
FeHd
FeHd's Avatar
Honda's used to have a "linked" system that applied both front and rear brakes with one lever.
Sportster Choppin Bastard CTFS
"dentists and bueracrats and pussyboy software designers gettin up on a Harley cuz they think it makes them cool. Well you aint cool skeeziks, your fuckin chilly. And chilly aint never been cool." GC
FeHd is offline   Reply With Quote
Old 01-16-2012, 11:43 AM   #15
Skibo
Skibo's Avatar
That's another option as well and it works though it precludes independent operation.
Old 01-16-2012, 03:41 PM   #16
Ducbsa
'70's BMWs have the front master cylinder under the tank. You could look at that.
Old 01-16-2012, 07:22 PM   #17
Loffer
Loffer's Avatar
[QUOTE=Skibo;794114]You're insane! I understand you're not knocking his parts but come on. I've got it mounted underneath my frame backbone and between my split tanks. It is the cylinder and mount and that's it. I don't see how it could be any smaller and still function well enough that I'd trust it to work. Kevin's stuff is tip top.
[/QUOT
Yep I am that is pretty small I was thinking of something else I guess. Kevins stuff is good. I know this about 2" of hose will suffice.
Old 01-16-2012, 07:35 PM   #18
Infidel 3-7
"Skibo" how is that actuated?
Infidel 3-7 is offline   Reply With Quote
Old 01-17-2012, 06:38 AM   #19
Skibo
Skibo's Avatar
Cable operated just like a mechanical brake. Then you just run a brake line down to the caliper. I plan on replacing the reservior with a much smaller cup so that when finished it will be hard to even know it's there.
Old 08-03-2013, 06:50 AM   #20
mcdamike
Hey Guys
So, which rear brake MC should I get to replace my stock single disc one piston brake, its a 9/16 bore.
mcdamike is offline   Reply With Quote
