Putting the "Sport" in Sportster - The Jockey Journal Board
Old 06-07-2011, 07:53 PM   #1
ShovelJockey
Default Putting the "Sport" in Sportster
Here is a few pictures of my latest project. It is an Ironhead with a 76 frame. The motor is a 1980, but more on that some other time. The front end is a Honda CB 750 that I fabricated neck cups to allow fitment. Wheels will be of Kawasaki KZ heritage. Ive been building it for a while and there is a lot of details, but instead of a friggin long write up, I will just answer any questions. Anyway, I just built a set of clip-ons for it, here they are.
By the way, before I get haggled too bad for having rusty forks let me explain that haha. They were cut down 2" and welded back together, and will be chromed. Figured it was easier to smooth them up than buy new ones.
The Kid
ShovelJockey is offline   Reply With Quote
Old 06-07-2011, 08:31 PM   #2
kickstarts
kickstarts's Avatar
Default Re: Putting the "Sport" in Sportster
Looks like a good start. I like that tank quite a bit and your rear fender setup.
Real tomato ketchup, Eddie?
kickstarts is offline   Reply With Quote
Old 06-07-2011, 10:00 PM   #3
ShovelJockey
I have been "starting" on this bike for more than a year now.....I know it doesnt look like it. I am meticulous about making sure things are the way they should be, so it takes forever. Anywho, this is all I had to start with. basically a good rotating assembly. I picked up a set of cases from Maryland and the frame came from Washington. There is already a Shovelhead in my stable, so there is no rush on this one.
The Kid
Old 06-08-2011, 08:22 PM   #4
ShovelJockey
A while back, I built a custom gas cap for this bike out of an old tractor radiator cap. The art deco tin over the radiator was removed from the radiator plug portion. After some careful head scratching, I figured out where the new cap would get tight and then made sure the tin was placed right. Now, when the cap gets tight, it sits straight with the tank.
The cap looked great, but needed to flow better. So today, I peaked the tank to bring it all together.
The Kid
Old 06-08-2011, 08:31 PM   #5
redrabbit
redrabbit's Avatar
ThAt tank is pretty cool man!!are you going to bond the spine...just curious
redrabbit is offline   Reply With Quote
Old 06-08-2011, 08:35 PM   #6
ShovelJockey
By bond do you mean "Bondo" i.e. bodyfiller, or do you mean weld it together?
Right now it is just tacked together, it will be fully welded later. With metal this thin it has to be slow goin's or else it will get reaaall curvy. On bits like this, I like to use lead to smooth things up. In the end, it may get a swipe of filler over it simply to smooth out the sand scratches. I dont like to use much for filler.
The Kid
Old 06-09-2011, 08:04 PM   #7
selectedgrub
selectedgrub's Avatar
Flow,
Yeah that's what we love.
Looking good Johnny.
Old 06-09-2011, 08:56 PM   #8
57 merc
Tank looks great! I really like that.
57 merc is offline   Reply With Quote
Old 06-09-2011, 09:20 PM   #9
gassy wynd
That look5 5weet man!
gassy wynd is offline   Reply With Quote
Old 06-09-2011, 10:03 PM   #10
Jeepster
Jeepster's Avatar
Damn!!!!!
"If Id' only known I would live this long,I woulda taken better care of myself"
Jeepster is offline   Reply With Quote
Old 06-09-2011, 10:14 PM   #11
ShovelJockey
The Kid
Old 06-09-2011, 10:16 PM   #12
ShovelJockey
Here are the neck cups I made to adapt the Honda front end to the Harley frame.
The Kid
Old 06-09-2011, 10:19 PM   #13
ShovelJockey
Aluminum oil tank made from an automatic livestock waterer's float system. Fill tube made from an old flashlight tube. The spring has been glued in so that it doesnt fall out.
The Kid
Old 06-10-2011, 02:45 PM   #14
Tritom
keep it coming!!
Tritom is offline   Reply With Quote
Old 06-10-2011, 04:13 PM   #15
Patrick46
Patrick46's Avatar
Great job...keep it up!
and that gas tank is BITCHIN'!!!
"Good Times & Good Friends Make Life Better!!!"
You don't quit riding because you get old...you get old because you quit riding!!
my graphics shop's site is...www.artworks-unlimited.com
Patrick46 is offline   Reply With Quote
Old 06-10-2011, 06:31 PM   #16
GEARS-N-GREASE
GEARS-N-GREASE's Avatar
lovin it
http://www.six-2.com
GEARS-N-GREASE is offline   Reply With Quote
Old 06-10-2011, 06:43 PM   #17
hogster
hogster's Avatar
Location: find the nicest trailer in the park,I live under it
why do you even have a spring in the cap if its threaded.?
looking for a good re-tox facility
hogster is offline   Reply With Quote
Old 06-10-2011, 08:35 PM   #18
ShovelJockey
Because it is made out of an old flashlight and the spring is required because there are dickheads out there that like to call bullshit. The spring is bullshit repellent. And maybe a dipstick...
The Kid
Old 06-10-2011, 10:07 PM   #19
Richharr
Richharr's Avatar
looks like you just glued a spring to the cap, I call bullshit
http://fucdatbirth.blogspot.com/
"semper fi" yeah I was miserable and tired for a few years too.
Richharr is offline   Reply With Quote
Old 06-10-2011, 10:20 PM   #20
Jeepster
Jeepster's Avatar
if you drop it accidently.....how far might it go?
