Russian K-750 Hardtail Shortchop - The Jockey Journal Board
Old 06-22-2010, 12:34 AM   #1
SwedeBobb
SwedeBobb's Avatar
Send a message via MSN to SwedeBobb
Default Russian K-750 Hardtail Shortchop
NEW FRAME MOCKUP W/ WHEELS AND TANK ON PAGE 8!
At last I got my bike home after having it sitting for a year at a friends house 600kms away:
When I got it home I cleaned some junk of such as fenders and mufflers and did some temporary wiring:
The bike have 6v electrical system but I had no battery so I taped on a 12v ignition coil and a lawnmover battery and then we pulled it with a friends car til it fired up and managed to run on its own engine(broke kick mechanism).
Back to the garage to pull the engine apart for a rebuild:
Thats about all could do tonight without waking up the family! After I have got some sleep I will weld the swingarm (gonna hardtail) and clean the frame and send it to sandblasting.
Will update after sleep and work
SwedeBobb is offline   Reply With Quote
Old 06-22-2010, 02:52 AM   #2
SwedeBobb
SwedeBobb's Avatar
Default Re: Russian K-750 Traditional Bobber(?) Project
No sleep but just a little more work and a dumbass question; on the pic below you can see that the cylinder to the right is all dry and the one to the left is wet! When i testdrove it the cylinder to the right was alot hotter and i checked the spark but it was just fine on both cylinders.. Whats my problem?
Closeups:
Old 06-22-2010, 03:37 AM   #3
Unkl Ian
Unkl Ian's Avatar
Location: Just past the corner of Hell and The Twilight Zone.
Stuck Oil ring or worn guides, allowing oil to contaminate the combustion chamber ?
FlyingEyeballs.net
Unkl Ian is offline   Reply With Quote
Old 06-22-2010, 04:17 AM   #4
SwedeBobb
SwedeBobb's Avatar
2 Unkl Ian: May be worn guides then, because the oil rings look fine and aint stuck! Will look at that for sure, thanks for the tip!
Amazing how fast u strip a bike:
Though I found this, looks ugly:
Old 06-22-2010, 06:55 AM   #5
cranberry
cranberry's Avatar
greetings from Ukraine dude! you have started working on it)) can't wait to see more progress coz u know why)
In my dream
I rule my life
And the sleeping beauty
Is my wife...
https://www.jockeyjournal.com/forum/s...ght=jawa+250cc
http://www.facebook.com/profile.php?id=100001746720357
cranberry is offline   Reply With Quote
Old 06-22-2010, 10:31 AM   #6
SwedeBobb
SwedeBobb's Avatar
Due to the crooked frame I decided to try to straighten it and hardtail it the same time.. I welded the swingarm to the frame and cut off the shock mounts. Also took the fork apart and it wasnt nice inside, thinking about buying a springer fork from www.bastybikes.com...
Will remove the upper tubing and weld new tubes from the swingarm to the backbone and then remove the tubing underneath and cut off the swingarm and weld the lover tubes..
Old 06-22-2010, 10:53 AM   #7
rgf
rgf's Avatar
good luck for your project!
my version:
rgf is offline   Reply With Quote
Old 06-22-2010, 01:35 PM   #8
Destralo Roach
Moderator
Destralo Roach's Avatar
Nice project!! Flywheels was from china but looked real cool as a bobber!!
..................Roach.
Old 06-22-2010, 03:09 PM   #9
Scab Vendor
Scab Vendor's Avatar
I'm diggin that passenger solo seat, cool project!
"Break your backs and crack your oars men, if you wish to prevail! "
Scab Vendor is offline   Reply With Quote
Old 06-22-2010, 03:48 PM   #10
SwedeBobb
SwedeBobb's Avatar
Thanks for the comments guys!
Speaking of flywheels (sort of), the lid in the gearbox that holds the kickspring in place had unthreaded and pressed against the clutch/flywheel, the kickpedal is welded on the kickaxle, all bearings are worthless and the complete gearbox looks like shait.. Crappy russian engineering! Luckily parts for these are not expensive. No more can be done tonight, but tomorrow Im gonna go pick up an impact driver and call a company nearby and check if they will blast my frame and som other shit..
PS! Sorry if my english suck or I translate wrong but hopefully u will understand
Old 06-22-2010, 03:54 PM   #11
danisdead
danisdead's Avatar
Looks like the fun has just began.
LTRRTC
danisdead is offline   Reply With Quote
Old 06-22-2010, 04:25 PM   #12
Spade115
Spade115's Avatar
Looks great, Always liked the way those motors look.
Spade115 is offline   Reply With Quote
Old 06-23-2010, 06:57 AM   #13
SwedeBobb
SwedeBobb's Avatar
Found these lose behind the timingcover, strange..
Anyways, going to town now to buy some new bolts and gasketmaterial, will get the frame and some other shit blasted tonight! Updates coming soon
Old 06-23-2010, 07:08 AM   #14
not45blesk
not45blesk's Avatar
this looks just like a great project!!!
You're Having fun now.
Why wonder if does bmw parts fit into the russian version ?
keep them coming!
Knot Blesk
3ciprestescycles
http://3ciprestescycles.blogspot.com
http://fatfredtowing.blogspot.com/
not45blesk is offline   Reply With Quote
Old 06-23-2010, 09:10 AM   #15
Picasoo MZ
Picasoo MZ's Avatar
Very nice project...keep on!!
Picasoo MZ is offline   Reply With Quote
Old 06-23-2010, 02:11 PM   #16
Destralo Roach
Moderator
keep them coming!
Yeah the German K75 will bolt on on most parts, same with the H-D XA.....Roach.
Old 06-23-2010, 03:19 PM   #17
SwedeBobb
SwedeBobb's Avatar
Thanks guys!
Roach: Good fact to know, thanks!
New gaskets and insexbolts, more coming (will grind and polish the alum later)
Blasted the parts of the frame that will be left and some other junk and primed the trees, pegs and risers. If I go with the original fork, wich I hope not too, I will cut of the light brackets(?) and go with some older headlight with yellow ribbed lens. Yum yum..
Hey, my stepdad is a biker too!
Tomorrow Ill go to a local company to see if I can fetch som cheap(free) tubes and start welding the rearend.. Lucky for me my stepdad has a pipe bending tool and mig welder at his work!
More updates tomorrow
Old 06-23-2010, 06:45 PM   #18
SwedeBobb
SwedeBobb's Avatar
Thought that I went to bed but, with so much plans and motivation I just cant sleep so I went down to the garage again..
Cut of the kick axle and disassembled the rest of the gearbox, going to town tomorrow with all the bearings, oilseals and some more bolts to get new ones. Dont really want to buy those particular spareparts from the dealer who takes them from Estonia...
Dished everything up real nice but the gearbox housing will take a bath in degreaser over the night. Also found out why the kicker didnt work, as I thought the heal was worn. Luckily new axle with complete kickmechanism only cost 48.50 $
Thought of making a list over money spent on this, I know its early but then it will be easier to keep count
The bike with sidecar: 641.23
New 6v batteri: 24.73
New bolts and gasketmaterial: 9.45
"Holepunching" tool kit: 9.94
Gasmoney for picking it up: ca 124.29
Sandblasting: 0 (Went to a friend and did it myself)
Primer: 0 (Had leftover in the garage)
More bolts and some bearings and oil seals: 50.10
Total of 859.74 $ (Will update as build goes on)
Old 06-24-2010, 12:18 AM   #19
Okie Pete
Okie Pete's Avatar
Thanks for the up dates. Looking good
Okie Pete is offline   Reply With Quote
Old 06-24-2010, 07:19 AM   #20
Picasoo MZ
Picasoo MZ's Avatar
Hey Bob...is that purple bike (that belong to your stepdad) Tomos or Puch ?
