Sissy Bar Fabrication. - The Jockey Journal Board
Old 10-21-2008, 06:14 AM   #1
kbg
Default Sissy Bar Fabrication.
always gives me the shits, i used to just chalk it out on the concrete floor and get someone to stand on it while i heat and bend.
Came up with this to make life easier.
Just some 1/4 plate with holes drilled in it so i can use threaded bungs to bend around, works a treat, not a new idea i would imagine.
Vb stubbie optional.
kbg is offline   Reply With Quote
Old 10-21-2008, 06:53 AM   #2
angustriple
angustriple's Avatar
Default Re: Sissy Bar Fabrication.
Theres your problem m8, its that VB try some mid strength, it lets you think longer, just trying to help
If at first you dont succeed, destroy all evidence that you tried.
angustriple is offline   Reply With Quote
Old 10-21-2008, 07:01 AM   #3
scraper
scraper's Avatar
awesome - thanks for the tip. im planning on building one for my next bike & was a bit foggy on getting everything nice & straight.
scraper is offline   Reply With Quote
Old 10-21-2008, 07:17 AM   #4
Gazza
Gazza's Avatar
Nice jig !!! In a pinch even a smaller one that does one side at a time works, but having a large enough sheet to keep it 100% symmetrical has got to be nicer...
Gazza
www.QuadCamBastards.com
Gazza is offline   Reply With Quote
Old 10-21-2008, 08:38 AM   #5
Nads
Symmetry is for pussies.
Nice work.
There's a fine line between a Hog Member and a hog's member.
Nads is offline   Reply With Quote
Old 10-21-2008, 09:14 AM   #6
Bugles
Bugles's Avatar
Just because you're unbalanced...
All joking aside, I've done my sissy bars (all three) using a mapp torch and 1/2" round stock wedged into my bench vise. Eyeballs and tape measures, steady hands and good sense for 'level'.
Cool set-up for mass production, though. I'd get all mental setting up a jig.
Bugles is offline   Reply With Quote
Old 10-21-2008, 09:25 AM   #7
DanK
DanK's Avatar
Nice setup kbg. How long does it take you to pound one of those out?
Steel / Aluminum / Brass / Copper Fenders
Stainless Sissy Bars
DanK is offline   Reply With Quote
Old 10-21-2008, 09:34 AM   #8
Trent
Atomic Custom
Trent's Avatar
Send a message via Yahoo to Trent
Thats how I have been making mine for years.. works great.
Atomic Trent
Atomic Custom
https://atomiccustom.bigcartel.com
http://instagram.com/atomictrent/
"Custom parts are good only when they're cooler than factory parts. By cooler I mean have better lines, work better, etc."
Trent is offline   Reply With Quote
Old 10-21-2008, 12:31 PM   #9
ryangobie
ryangobie's Avatar
big ups on this thread. quite timely. i should be doing mine sometime this week. just made up a piece of flatstock for my fender support
-Ryan
ryangobie is offline   Reply With Quote
Old 10-21-2008, 01:15 PM   #10
bongoman
bongoman's Avatar
Damn....where was this thread when I needed it?!? Great fixtures. What did you use for measurments?
Made this with my eye-crometers only....
The Purple Piper plays his tune, the choir softly sing, three lullabies in an ancient tongue, in the court of the Crimson King.....KC
bongoman is offline   Reply With Quote
Old 10-21-2008, 01:23 PM   #11
Toecutterp
Toecutterp's Avatar
Is that for your gate?
Toecutterp is offline   Reply With Quote
Old 10-21-2008, 01:31 PM   #12
bongoman
bongoman's Avatar
I know - looks like wrought iron. But no, it's a little devil's tail, powder coated black...looks better on the bike.....but now that I know the trick to making a better one......
Old 10-22-2008, 03:02 AM   #13
kbg
About five minutes once you lay it out.
Angustriple, the Vb is a middy, i only drink heavy when i gotta use the nine inch.
