Home made workshop tools - The Jockey Journal Board
Old 11-22-2007, 09:52 PM   #1
ca180
ca180's Avatar
Default Home made workshop tools
Just wanted to see what kind of home made tools and stuff you guys have... I've already heard of a few.
On guy said a washing machine motor for a buffer.
Also seen a drill in a vice and a grinder become a lathe.
What else ya'll got?
ca180 is offline   Reply With Quote
Old 11-23-2007, 12:18 AM   #2
nfms39
nfms39's Avatar
Default Re: Home made workshop tools
i'd like to hear what guys use instead of to get the job done... i think this would be a good thread...
nfms39 is offline   Reply With Quote
Old 11-23-2007, 12:27 AM   #3
Neo Dutch
Neo Dutch's Avatar
Buffer stand. Also holds elecky motor with a wire wheel on it. Buff comes off and a bar bender can bolt to the top. Base is a Leopard tank road wheel.
Chuck that Knuck, Flat is where it's At.
Neo Dutch is offline   Reply With Quote
Old 11-23-2007, 01:17 PM   #4
ca180
ca180's Avatar
I used to have a bench grinder stand made out of an extra wheel and a used driveshaft. Worked like a charm, but would vibrate half way across the room if you didnt keep your foot on it.
All this has me wondering if I could make a decent small scale lathe out of my drill press.
Keep em coming, good ideas I don't think I've thought of! Its amazing how you realize you need something when someone shows what they've got.
Old 11-23-2007, 05:59 PM   #5
machobuck
machobuck's Avatar
Looking for work...
machobuck is offline   Reply With Quote
Old 11-25-2007, 04:24 AM   #6
chopaweeza
chopaweeza's Avatar
Send a message via Yahoo to chopaweeza Send a message via Skype™ to chopaweeza
Tubing Bender. Design by Blackjack. Adapted to take a locally produced hatchback hub. I've built several frames with it so far and recommend it highly
Easy enough to use that even Neo Dutch had a go.
chopaweeza is offline   Reply With Quote
Old 11-25-2007, 03:42 PM   #7
Ea$y
This is RAD!! Im sooo gonna copy that!Hope ya dont mind.
Awesome tech thread!
"Support America shoot a politician."
Ea$y is offline   Reply With Quote
Old 11-25-2007, 05:13 PM   #8
ca180
ca180's Avatar
So what Hatch back hub do you use with that?
Old 11-25-2007, 05:49 PM   #9
concrete guy
Here's a tubing notcher that I made got it from some guy off the net. It works well.
concrete guy is offline   Reply With Quote
Old 11-25-2007, 06:18 PM   #10
chopaweeza
chopaweeza's Avatar
It works very well and will replicate bends easily. I use a high tech method to replicate bends. I mark the hub with a piece of chalk and then bend the next piece to were the chalk mark is. I used a Holden Barina hub which is common as muck here , Blackjack used a Ford Fiesta and I've heard some guys in the USA use Rabbit or Jack Rabbit(memories not so good) hub as well. It's a very flexible design that has at least 12 variants that I know of . It's Low Tech but it works. Here's where to find it.
http://www.thefont.pwp.blueyonder.co...ube_bender.htm
Old 11-25-2007, 08:26 PM   #11
RAZ
RAZ's Avatar
This is what I made to put louvers in exhaust tube for making baffels
I use the angle aluminium to shim for different diameter tubing.
Work out?? I don`t need to work out, I get
enough exercise just pushing my luck.
RAZ is offline   Reply With Quote
Old 11-25-2007, 10:17 PM   #12
flattracklarry
flattracklarry's Avatar
Sorry man, but ^that^ thing looks like a quick trip to the ER.
Make a long story short. Don't tell it.
flattracklarry is offline   Reply With Quote
Old 11-26-2007, 12:21 AM   #13
ca180
ca180's Avatar
+1
If I build that I'm going to try to intigrate a hydraulic jack.... I really dont wanna bust my ass.
Old 11-26-2007, 12:24 AM   #14
Rob Axel
Rob Axel's Avatar
Adding a "strap" wouldn't be a bad Idea to keep that from exploading if it slips off.
Old 11-26-2007, 09:07 AM   #15
Bad Liver
There was a thread about engine turning finishes recently. You can glue some sandpaper to the bottom of a valve and stick that in your drill to use for engine turning. Bigger valve, bigger pattern.
Im invisible cause I say so
Bad Liver is offline   Reply With Quote
Old 11-26-2007, 10:48 AM   #16
scootermcrad
scootermcrad's Avatar
Great thread! I think this was started once before but didn't get even close to being this big.
I've got a thingamajig I made for engine turning. I'll try and get a picture of it.
BTTT
Blogs are weird... here's mine!
http://scootermcrad.blogspot.com/
scootermcrad is offline   Reply With Quote
Old 11-27-2007, 06:46 PM   #17
F.St.M.
F.St.M.'s Avatar
I got a homemade wheel truing stand:
I got a homemade clutch hub puller:
And last but not least, I got a homemade phase converter so I can run my 3-phase mill & lathe off of residential 220 juice:
F.St.M. is offline   Reply With Quote
Old 11-27-2007, 07:39 PM   #18
ca180
ca180's Avatar
On the topic of that pipe bender... I was thinking that a come-along strapped to it would probably make the bending easier. Maybe safer, unless the cable breaks.
Love where this is going!
Gotta see more stuff. I'm just a broke white boy, cant afford lathes and pipe benders and all that shit.
Old 11-27-2007, 07:57 PM   #19
#1.
#1.'s Avatar
Oil furnace broke.
Replaced with gas furnace.
Needed a use for old furnace fan.
This thing blows the smoke out of the garage when I am welding or when I set something on fire.
#1. is offline   Reply With Quote
Old 11-27-2007, 08:45 PM   #20
scootermcrad
Originally Posted by #1. View Post
Oil furnace broke.
That thing rules! So does the sign to the left of it!!
