#1 |
I'm pretty excited to have been able to get this. I never thought I'd land one. It belonged to a friend of mine who passed away and I was asked if I wanted it, I made an offer, and now it's mine. It's '49 motor, I assume 49 frame. Mousetrap, later non-tank shift tank, aftermarket dash, I think later forks, and some other stuff. I'm going to get it checked out at some point to figure out what's what. Last registered 1986, 354 miles on the odo, probably restored late 70's, early 80's. I brought it home and it sparks, would love for some advice on how I should go through all the systems before I hopefully fire it.
![]() doesn't appear to be right bags, but I kinda like the look. ![]() ![]() ![]() some extras. I think the buddy seat is after market but the rail is original. ![]() Last edited by vorhese; 01-31-2015 at 08:58 PM. |
Sponsored Links | |||
#2 |
you should remove any rust in the gas tanks - drain oils motor and trans - remove and over haul the carb < have it sonic cleaned is best - adjust the valves - replace the sparkplugs and the points and condenser - the engine block is full of oil as the system is gravity feed - and sitting that long all the oil from the tank is in the block
BTW - its going to make a mess when you get it started center srand it and drain pan the bottom Sometimes the block plug comes in and out easy - but most times it does not - i would leave it alone if i were you and deal with the oil with drain pans you will need the factory books the service and the parts books as asking questions with the correct names and part numbers will help the guys who help out, to be on the same page so to speak sweet ride good luck
Ineptocracy (in-ep-toc'-ra-cy) - a system of government where the least capable to lead are elected by the least capable of producing, and where the members of society least likely to sustain themselves or succeed, are rewarded with goods and services paid for by the confiscated wealth of a diminishing number of producers |
#3 |
I have no doubt it will turn out perfect. Enjoy the education and the fun getting to know it.
60% of the time, it works every time... |
#4 |
Very nice bike , enjoy it , listen to it and it will teach you its quirks .
Not enough time for windmills |
#5 |
That is a beautiful bike. It would have been nice if mine looking like that when I bought it.
#6 |
Congrats ,that's a beauty. Had to build mine from parts...HD's Panhead Service Manual 1948-47 is a must (got mine for 15 bucks off ebay- reprints are expensive), Rick Schunks 'How to Rebuild and Restore Classic Harley Davidson Big Twins 1936-1964' has been useful too.BTW -I think only 1948 m.y. had springers- those could be the original forks.
All men are equal when their memory fades |
#7 |
^^^Doh-should read 1948-1957 above.... Get that buddy seat on and take the kids and the missus for a spin...
#8 |
BOY did you do good for 1st harley ! leave it bone stock. when your as old as me you,ll tripple your investment and just think of all the fun ridin it you,ll have inbetween !!!!!
I BELIEVE IN JOHN 3:16 |
#9 |
Yeah man, very nice score and that is one beautiful machine !!
Jon "And now you do what they told ya" |
#10 |
Along with what John said about draining the oils and the lower end being full and draining it, as long as she has set, this is almost like firing a fresh motor.
I'd pull the plugs and squirt some lube in the cylinders, I was taught to use dot3 but some people don't like that idea but, use something to lube it and hopefully eat some of the surface rust and it should drain past the rings so the piston skirts arn't dry. With the plugs still out after it has set for a while, I'd pull the cap on the oil pump and the spring and check ball then slowly kick it over until oil comes out, then replace everything and button it back up. If everything else is all right, now you have fresh oil ready to lube. The next thing I'd be concerned with would be the wiring system. I'm sure someone has replaced it by now but, I'd at least run every wire down looking for brittleness and corrosion. I would think the voltage regulator would need to be phased also. Congrats on a beautiful piece of machinery, D
"Apparently, any asshole can wrench on a newish, un-fuckered bike. Takes a goddamn genius to take this shit on."-Liam. |
#11 |
very nice, congrats on getting your friends bike after his passing. I'm a house guy as well as a bike guy and wow that cedar clapboard is just as amazing to me as your bike......be well
'81 Shovel. '75 XLH project. |
#12 |
Congrats on the Pan, good on you.
Fresh Oils, fuel carb cleaning and battery and I'm sure it will start Let us know how things work out. Lester
'62 DuoGlide Mine for 25yrs '62 Triumph T-Bird in boxes '83 BMW R100 commuter '52 Triumph Speed Twin Bastard '80's couple of Jap chops too ![]() |
#13 |
My first big twin was a 61 pan. Practice the starting ritual and you'll be having fun in no time. Great bike.
Pay no attention to the garage!! My best work comes from chaos!! |
#14 |
Congrats Vorhese!
Thats a very nice Pan |
#15 |
Very jealous. Not sure why the young lady in the photo is smiling....standing so close to her man's mistress and all. Just sayin!
#16 |
Super Moderator
Take your time and go through everything, nice score!
"No one knows what they don't know." - Govmule84, Wannabe Hipster |
#17 |
She probably has plans to ride it!! He may need to find his own bike in the long run...
#18 |
Forum Dipshit
#19 |
Thanks for the advice fellas! I think she is smiling for a couple reasons. She's happy it's going to someone who will appreciate it. In her words, it would have made her hubby very happy. Also the fact that she never got to see the thing actually ride and that I promised her that her son would get to ride it someday. It was an emotional day.
I think they are later forks because the 49, first year of the telescopic fork, had sandcast lower fork legs painted black. And the headlight shroud didn't say "HydraGlide" which this one does (1950-1959). Could anyone tell me what the heck the spring connected to the fender (by the seat) does? The wiring looks brand new. It probably was redone back when. It's converted to 12V. After getting her running replacing the dash with a non-repop will probably be first on my list. ![]() ![]() ![]() |
#20 |
Forum Dipshit
I am not an expert, but I thought those were buddy seat helper springs.
Display Modes | |
