Triumph Negative Ground Wiring - The Jockey Journal Board
Old 02-12-2014, 12:06 PM   #1
carspanc
Default Triumph Negative Ground Wiring
I picked up this 71 Triumph chopper recently and decided to re-wire it to negative ground since the wiring was a mess and I wanted to run an LED tail light. It ran fine before but took a lot of kicking to get started. Could have been old gas and carb adjustment, I'll dig into that later. I have no spark now though. I attached a wiring diagram of what I have now, if someone could let me know what is wrong with it I'll fix it and repost for easy searching later.
Edit: Posted corrected wiring diagram
Name:	Triumph Wiring.jpg
carspanc is offline   Reply With Quote
Old 02-12-2014, 12:27 PM   #2
Rob Axel
Rob Axel's Avatar
Default Re: Triumph Negative Ground Wiring
First....are you running a Boyer E.I.?, second....have you given the battery a FULL charge? Boyer E.I.s are known to hate low voltage.
...duel coils? 6 or 12v? also I believe some E.I.s are very specific about ohms on coils...
"The heart is happiest
Old 02-12-2014, 12:31 PM   #3
carspanc
Boyer MK3 EI. Battery was hooked up to my battery minder the whole time I was wiring so should have a full charge.
Old 02-12-2014, 12:48 PM   #4
supercrouton
supercrouton's Avatar
According to your diagram, your Boyer does not appear to have a ground path. Without a ground path, the "power" circuit is not complete, and the Boyer won't do anything at all. The Boyer needs to "see" a positive and negative from the battery/switch to begin to function.
Old 02-12-2014, 12:51 PM   #5
carspanc
Okay that makes sense. So I should run my black wire from the Boyer to ground then ground the - side of the left coil?
Old 02-12-2014, 01:13 PM   #6
supercrouton
try this....
Old 02-12-2014, 04:10 PM   #7
carspanc
Perfect! Fired up right away for me. Thanks
Old 02-12-2014, 05:15 PM   #8
Rob Axel
Rob Axel's Avatar
Bingo!...
Old 02-13-2014, 11:34 AM   #9
carspanc
Okay I went ahead and fixed my diagram and put it in the first post as well as this one. Hopefully that helps someone searching in the future since I couldn't find a good diagram for negative ground with EI.
