S&S Carb support pics help? - The Jockey Journal Board
Old 07-18-2013, 10:44 AM   #1
gretsch58
gretsch58's Avatar
Send a message via Yahoo to gretsch58
Default S&S Carb support pics help?
I know a lot of you guys run a S&S Super E or G and run a small filter or custom filter besides the tear drop S&S which has the bolt hole for the air cleaner support. Shovelheads of course.
I'm looking for ideas or pictures of how you guys may have fab'd a new support for the carb when using a small custom air cleaner.
Any help is appreciated. I did try to search but found nothing.
Thanks
B~
http://www.18wheeler.net
gretsch58 is offline   Reply With Quote
Old 07-18-2013, 11:14 AM   #2
Irish Rich
Irish Rich's Avatar
Default Re: S&S Carb support pics help?
The strap brace from the top center case bolt, to the bottom carb manifold bolt is about as simple and supportive as you can get. That's what I use on Shovels.
Irish Rich is offline   Reply With Quote
Old 07-18-2013, 11:24 AM   #3
govmule84
Forum Dipshit
I made mine the same way out of 1/8" stock with two hole drilled in it. Haven't run it yet, but it looks like I could hang laundry on the carb with no problem.
Old 07-18-2013, 11:29 AM   #4
Cks-Designs
Cks-Designs's Avatar
mine was pretty simple... just powdercoated it black...
Used countersunk bung's from bungking.com... if that helps
Cks-Designs is offline   Reply With Quote
Old 07-18-2013, 11:30 AM   #5
ralphiejantz
yup thats the best one to use works great
Vtwin sells them but they list them for a super B carb but they fit a super E carb just fine as well
ive run those on pans and shovels without a problem
and Im pretty sure S&S sells its own as well that is the same style Vtwin sells
Theyre usually like $20
http://syndicatechoppers.com
authorized dealer for
Biltwell Inc
Lowbrow Customs
Buchanans Spoke and Rim
Wargasser Speed Shop
Universal Vintage Tires
Paughco
V-Twin MFG.
Fab Kevin
Colony Machine
Morris Magneto
Baker Drivetrain
Andrews
Cycle Electric
Old 07-18-2013, 01:47 PM   #6
hardtop
hardtop's Avatar
mine was tricky because of this oil line kit i was running. i had to bend the plate to clear the oil line and still clear the jugs too. and the bend back in a different plane to line up with intake manifold. its funny little hidden detail but i was pretty happy with it.
ID:	95818   Click image for larger version
ID:	95826   Click image for larger version
ID:	95842   Click image for larger version
ID:	95850   Click image for larger version
hardtop is offline   Reply With Quote
Old 07-18-2013, 03:14 PM   #7
gretsch58
gretsch58's Avatar
Awesome! thanks for the pictures and quick responses. I am running a set of Ultima cases, so I don't think there is a case bolt in that spot. I'll look when i get home.
Old 07-18-2013, 03:19 PM   #8
gretsch58
gretsch58's Avatar
Thumbs up Re: S&S Carb support pics help?
This is kind of what I was thinking.
Old 07-18-2013, 04:17 PM   #9
smkostek
smkostek's Avatar
I like the bung idea I might be checking that out for myself!
smkostek is offline   Reply With Quote
Old 07-18-2013, 06:07 PM   #10
FearNoEvo
FearNoEvo's Avatar
I broke 3 of those before I gave up on that option. I ended up building one out of angle iron and going from both rocker boxes to the backing plate with a couple of studs. Never so much as a crack and vacuum leaks are a thing of the past.
Keihin carb, but same difference.
Excuse the dirt, or don't, she's been parked for a while with an inner primary that is broken in half. Wheelies. Lots of them!
ID:	95922   Click image for larger version
FearNoEvo is offline   Reply With Quote
Old 07-19-2013, 07:30 AM   #11
Rusty-Shackleford
Rusty-Shackleford's Avatar
You broke several carb mount straps and the inner primary is broken in half?
Hmmm maybe you are doing something wrong?
Rusty-Shackleford is offline   Reply With Quote
Old 07-19-2013, 08:21 AM   #12
gretsch58
gretsch58's Avatar
Originally Posted by Dragstews View Post
If your rocker Boxes are OEM you may have this bolt hole that can be used as a carb support.
http://i279.photobucket.com/albums/k...psac3d6e38.jpg
BTY....^^ Nice Motor ^^
Support bracket for Super E and G carburetors on Harley-Davidson® motorcycles with shovelhead engines. Supports air cleaner to the rear of the front rocker box.
MSRP:
$6.65
PN: 17-0392
I have this one already and was being used with my S&S tear drop air cleaner. But I'm gonna change the air cleaner and mount. So this won't work with the bird deflector air cleaner I'm looking to use.
Old 07-19-2013, 04:04 PM   #13
Cks-Designs
i guess if you wanted more support you could double up the head bolt connection point similar to the angle iron idea... mine seems very rock solid how i have it (went with the nice band clamps) i dont do wheelies... got sport bikes for that shit..lol
Old 07-19-2013, 05:33 PM   #14
gretsch58
gretsch58's Avatar
I like your idea/picture you posted...that's all I really need is something to replace the original support....
Old 07-20-2013, 03:02 AM   #15
FearNoEvo
FearNoEvo's Avatar
Completely unrelated.
Unless by wrong, you meant beating it like a rented mule.
I went through the carb mount troubles right after I bought it.
The broken inner primary happened last year. Some 25 years into our relationship.
Wheelies. Lots of them. Its hard on parts.
Did I mention that I jumped it so high that it broke both shocks off? Foot pegs too?
Maybe I should have mentioned that.
Old 07-20-2013, 09:03 AM   #16
CB550 Matt
CB550 Matt's Avatar
Here is my start to one
And
Still got some work to go on it but it is a start
No one really takes a BSA apart unless it needs a rebuild, or they are high.... sometimes both.
Originally Posted by Tony the torch View Post
The rev limiter appears to be the size of your balls.
CB550 Matt is offline   Reply With Quote
Old 07-20-2013, 10:13 AM   #17
Rusty-Shackleford
I kinda like that!
Old 07-20-2013, 10:31 AM   #18
CB550 Matt
CB550 Matt's Avatar
thanks! it might require some fancier bends to clear the top motor mount that sticks down, but it is work in progress.
Old 07-20-2013, 01:14 PM   #19
Rusty-Shackleford
I think it would look nice done in stainless round stock.
Old 07-29-2013, 09:53 AM   #20
gretsch58
gretsch58's Avatar
@CB550_Matt. I like that idea too. I may try that. Here's what I did for the time being. I have minimal tools to work with.
