Pinstriping one shot question?? - The Jockey Journal Board
Old 11-27-2012, 10:09 PM   #1
drumrooster
drumrooster's Avatar
Default Pinstriping one shot question??
I just pinstriped something 2 days ago with one shot red on top of black acrilic enamal paint...will it hurt the one shot if i spray acrilic enamal clear over top of it all now? or would it react with the one shot?..oh and I didn"t thin the one shot at all..
its fresh only a few days old?
"NO PICTURE. NEVER HAPPENED..."
drumrooster is offline   Reply With Quote
Old 11-27-2012, 10:21 PM   #2
leftypoorboy
Default Re: Pinstriping one shot question??
try a test panel, but it's probably going to wrinkle up the 1shot. If you are going to go for it, give it a very light first coat, with time to flash off until it's mostly dry, then follow with heavier coats.
leftypoorboy is offline   Reply With Quote
Old 11-27-2012, 10:27 PM   #3
Rob Axel
Rob Axel's Avatar
I would give it a couple more days....just to make sure it is completely dry..then do a "dust coat" ...then build coats ..slowly.
any reason you are going with Acrylic enamel rather than urethane?
"The heart is happiest
Old 11-27-2012, 10:52 PM   #4
drumrooster
yea I got a test panel I did I can spray over that and see what happens.. just had the acrilic enamal..and its cheap..lol..I got some clear to protect it..its on a show cart for my daughters mini horse..I used a Bugler pinstrip tool so I didnt thin the one shot any..is that ok?..just dont wann ruin it after all the work,,
Old 11-27-2012, 11:33 PM   #5
Unkl Ian
Unkl Ian's Avatar
Location: Just past the corner of Hell and The Twilight Zone.
Depends on the solvent in the clear.
I ruined a job last week, using the wrong stuff. Not happy.
Rob Axle has the right idea.
FlyingEyeballs.net
Unkl Ian is offline   Reply With Quote
Old 11-28-2012, 08:48 AM   #6
Donzzilla
Donzzilla's Avatar
The one shot over the enamel is very durable, if it gets scratched off, touch ups will be easy. Chances of messing up all of your nice work by clearing it is very good. I'd leave it alone. It will be fine.
Zilla!
Donzzilla is offline   Reply With Quote
Old 11-28-2012, 10:44 AM   #7
drumrooster
thanks im gonna leave it alone.lol,,the guys at 1 Shot said I should have used the 1 shot hardner if I"m gonna clear it..$45 a damm can oh well maybe this will help someone else thinking about that..thanks brothers..
Old 11-28-2012, 11:53 AM   #8
Unkl Ian
Unkl Ian's Avatar
Most cars don't have their stripes cleared over.
FlyingEyeballs.net
Old 11-28-2012, 12:03 PM   #9
FlameThrower
FlameThrower's Avatar
If you used the hardener with the One-Shot, I would like your chances. Without it... my experience is that it will likely wrinkle around the edges a little/lot almost no matter what you do when spraying the clearcoat. That's why i only use HOK striping enamel... I've literally NEVER had it wrinkle when I clearcoat over it.
Good luck, man. If you go for it, allow it to sit a few days and spray the first couple coats of clear VERY lightly in hopes it will "seal" out the solvents from the later, heavier coats.
www.flamethrowercustoms.blogspot.com
www.flamethrowercustoms.com
FlameThrower is offline   Reply With Quote
Old 11-28-2012, 03:39 PM   #10
Slabside Mike
The "period correct" method is no clear over pinstripes. I just had to say it! LOL
By the way, your work looks good.
Slabside Mike is offline   Reply With Quote
Old 11-28-2012, 04:17 PM   #11
sugarlou
sugarlou's Avatar
"show cart for a mini horse"
Theres something we city slickers dont hear everyday.
Nice lookin lines
sugarlou is offline   Reply With Quote
Old 11-28-2012, 06:59 PM   #12
goliathcorso
Dry spray first couple of coats of clear. Then spray wet coat after several dry cots. Allow dry coats to dry well before the wet coat. It can be done over HOC if you stripe with it instead of one shot also. Dry spraying a few coats works.
goliathcorso is offline   Reply With Quote
Old 11-28-2012, 07:18 PM   #13
spent
spent's Avatar
I can't really add much to what is already said, so I'll just concur that the lines will probably wrinkle with a good coat of clear. The longer you let it cure, the better your odds are of a clean outcome. The 1-Shot hardener helps, and HOK striping paint is made to be cleared over.
You have the right idea by just letting it be. 1-shot is tough as hell, and traditionally striping wasnt cleared over. Cart looks pretty good, btw. Don't touch it, I'm sure your daughter will be stoked.
spent is offline   Reply With Quote
Old 11-28-2012, 09:36 PM   #14
slim55g
slim55g's Avatar
Holy shit,, thats the biggest swing arm i've ever seen,, i guess thats for the new 3000 series tire!!!!
slim55g is offline   Reply With Quote
Old 12-03-2012, 05:19 PM   #15
BigNick1959
BigNick1959's Avatar
If this was 10 years ago I would say don't clear it, but the new 1-Shot red is just shit! it will turn flat on you in about 6 weeks. I have my stripes cleared with HOK clears all the time (1-Shot lines let sit 24 hours) The key as others have said here are dry coats (Real dry!!) untill you get a build up over the lines then some medium coats. If you are using an enamal clear you should be OK, but still build up slowly. Since you didn't thin the 1-shot (which helps it cure) I wouldent clear it for a week, or you can blast it with a heat lamp or the best is to set it in the sun for a couple days.
Good Luck!
www.bignicksgarage.com
Pinstriping,Lettering,Airbrushing
BigNick1959 is offline   Reply With Quote
Old 12-03-2012, 06:18 PM   #16
FlameThrower
Good Luck!
I gotta say that I lay wet coats over HOK striping enamel almost immediately after they have cured... never lifts or does anything weird. One-Shot is the standard of the industry... but the HOK striping enamels really are great.
Old 12-03-2012, 08:37 PM   #17
Unkl Ian
Unkl Ian's Avatar
HOK is designed to be cleared over.
Different chemistry.
FlyingEyeballs.net
Old 12-04-2012, 07:25 PM   #18
BigNick1959
I don't mind using HOK striping paints if I have to, they flow real nice now but when they first came out they werent very good. I have one customer that makes me use it all the time, but it makes my eyes water and my nose runs like crazy! Not good to have a leaky nose when you're bent over a gas tank
Old 12-04-2012, 07:29 PM   #19
BigNick1959
Ian, dident they have a reducer that you could use with HOK striping paints if it wasent going to be cleared over. I think it used to leave the paint with a gloss. I don't know if HOK still makes that product.
Old 12-04-2012, 08:28 PM   #20
Unkl Ian
Unkl Ian's Avatar
IIRC, it needed to be catalyzed, if you were not clearing over it.
The opposite of 1-Shot.
I've only used it enough to say Yes.
Price and availability were part of that decision.
FlyingEyeballs.net
