Rear Sprocket position/chain alignment - The Jockey Journal Board
Old 04-16-2019, 12:25 PM   #1
hammerweight
hammerweight's Avatar
Default Rear Sprocket position/chain alignment
Hey Guys
Had a look around on previous posts and couldn't find an answer to my quandary.
Here's the deal...
My build is a 79 fxe frame with a 79 ratchet top 4 speed and a 67 to 72 rear swing arm and drum etc.
The issue is that the rear sprocket is 3/16" to 1/4" inboard of the trans sprocket.
Nothing bent etc, everything squared up.
Anyone else had this issue when converting to a juice rear drum from a previous disc brake setup?
Thanks!
www.marshallmetalshaping.com
hammerweight is offline   Reply With Quote
Old 04-16-2019, 01:24 PM   #2
govmule84
Forum Dipshit
Default Re: Rear Sprocket position/chain alignment
I think your ratchet top might be earlier... last year for those is '78 1/2, I believe. But that's neither here nor there.
I have had this problem before. I just used a dished (offset) rear sprocky.
Old 04-16-2019, 01:56 PM   #3
hammerweight
Default
No can do....drum brake
Sprocket is integral to drum.
Thanks all the same
Old 04-16-2019, 01:58 PM   #4
govmule84
Forum Dipshit
Ah, I thought you were going the other way around. Readers are leaders.
You need to swap your trans mainshaft, then, I believe.
You may find this useful: https://www.jockeyjournal.com/forum/...d.php?t=114746
I would think, too, there must be a factory axle spacer setup that should work, as a ratchet top and a juice drum was a factory combo.
Or do you actually have a rotary top?
Old 04-16-2019, 02:14 PM   #5
Dan Boy
Dan Boy's Avatar
Can you not off set the hub by re-spacing and then off set you rim via the spokes to compensate and have your wheel run central?
Blown Triple Build
Old 04-16-2019, 03:05 PM   #6
hammerweight
Default
Main shaft length doesn't alter the sprocket position.
Ratchet top for sure.....
Old 04-16-2019, 03:53 PM   #7
govmule84
Forum Dipshit
Ah, of course. So since the trans sprocket didn't move at all... good news! Everything lines up!
I'ma take one more crack and see how strong my Google-Fu is today. If this doesn't help, fuck it, I'm going to bed.
http://www.hydra-glide.com/phpBB3/viewtopic.php?t=6185
Old 04-16-2019, 03:54 PM   #8
hammerweight
Default
Hey Dan boy,
Afraid you have no side to side adjustment with the drum brake setup....
The spacers are the spacers.
Old 04-16-2019, 04:46 PM   #9
govmule84
Forum Dipshit
Check that link I wrote up there... I think Dan Boy nailed it. Apparently the manual tells you to kick the rim over; guy in the link had the exact same problem you do.
Do you have a manual? I think I have a Pan manual at home if you don't; I can scan the relevant info for you if you need.
Old 04-17-2019, 10:57 AM   #10
joe49
joe49's Avatar
The spacer on the main direct changed in early '77 it fit '37-E'77 P/N 35171-37.
Late '77 to '79 P/N 35070-77
'80 to '81 P/N 35070-80
'82 to '85 chain drive P/N 35079-82A or 35079-84
'82 to '86 belt drive P/N 35070-82A or 35070-84
You need the early one, you will need the seal too for the change out. Early '37 to E'79 is P/N 35230-39 or late'79 to '81 P/N 37741-67
Also in'80 there was a sprocket spacer added P/N 35079-80 and a sprocket change.
If your's has the spacer, deleting it maybe enough.
OLD MOTORCYCLE ENTHUSIAST
Old 04-21-2019, 09:33 AM   #11
hammerweight
Hey Guys,
Found the problem...
You would never think, but I guess if these parts could talk!
Drum rivet flange had been “narrowed” to adjust the sprocket at some time in the past. Check the pic.
Installed a non-muckedwith drum and voila.....perfect alignment.
Thanks for the input.
Old 04-21-2019, 08:32 PM   #12
JAWS
JAWS's Avatar
I wouldn’t have guessed that ever...
Who does that kinda mod to a drum?
Old 04-21-2019, 10:48 PM   #13
hammerweight
I don’t know man...I figure some kinda modified bike where the guy had major alignment problems...lol.
Old 04-22-2019, 01:02 AM   #14
FredoTwoWheels
FredoTwoWheels's Avatar
Wow, nice find, I would have never noticed.
VL SPRING SHIELD WANTED
IG: PineboxRecording
Old 04-22-2019, 04:11 AM   #15
rhysmort
rhysmort's Avatar
Originally Posted by hammerweight View Post
Hey Guys,
You must have eyes like a shit house rat to notice that! Who said size doesn't matter aye?!
Similar Threads
wanted early ironhead rear sprocket cover ralphiejantz Wanted 0 12-08-2011 03:09 PM
Sprocket alignment SpartanSPS The Board 13 09-19-2010 09:28 AM
rear wheel alignment timw82 The Board 5 02-08-2008 08:01 AM
Rear sprocket. Offset or no offset? NewYorkAndy The Board 13 08-21-2007 01:33 PM
