Stripped Magneto/Breaker Hole - The Jockey Journal Board
Old 12-04-2018, 11:47 PM   #1
FredoTwoWheels
FredoTwoWheels's Avatar
Default Stripped Magneto/Breaker Hole
The hole that holds my magneto secure is stripped. I have some 1/4-24 helicoils, but no insertion tool and I need to get up and running quick. Would I be better off drilling it and tapping it for 5/16 or should I attempt the helicoil without the tool? How much meat is surrounding that area in the case?
VL SPRING SHIELD WANTED
IG: PineboxRecording
Old 12-05-2018, 04:10 AM   #2
Thunderbird
Default Re: Stripped Magneto/Breaker Hole
make an insertion tool? they're pretty basic.
Old 12-05-2018, 07:43 AM   #3
CookieMonster
CookieMonster's Avatar
Do you have the tap? Proper Helicoil taps are not necessarily standard threads and usually come in the kit. An insertion too should be easy to make.
Old 12-05-2018, 08:58 AM   #4
johnjzjz
johnjzjz's Avatar
any 1/4 inch insertion tool is the same its not thread specific like the tap
seen many made 5/16 to repair second or third time maybe - what we did was drill and tap the 5/16 to 1/4 X 24 double nut the stud we make from a bolt and install it back to original - welding is the other way
Old 12-05-2018, 12:18 PM   #5
FredoTwoWheels
It was my understanding I would need an insertion tool of the same thread. I read about making one by sawing a slit in a bolt, but the only 1/4-24 bolt I have is the one for the mag, and I had to order it off ebay they are not easy to find (or were not when I was building the bike) If the tools are not thread specific though, I'll just go buy a 1/4-20 kit and use the tool, thanks guys.
Old 12-05-2018, 03:00 PM   #6
johnjzjz
johnjzjz's Avatar
it is thread specific and worse then that if you run a 1/4 X 20 tap and not a heli coil tap you will do two things
first - you will only end up with a 60 percent thread using a 1/4 X20 tap and we are talking about aluminum - it will strip right out again as it s not deep enough
second thing - if you use a 1/4 X 20 tap and that happens = step two - the 1/x4 24 heli coil is also compromised as the course thread 20 is deeper and the 24 thread is considered a fine thread and the coil thread will be shallow not as shallow as with the regular tap BUT <<<<<
this is the reason in the end so many have a 5/16 X 18 thread and the bolt head need to be modified to use it on a mag
in the end its all effed up and still not right going the easy way
your choice - do it right the first time - or what ever happens happens
Old 12-05-2018, 04:27 PM   #7
ericthebeard
ericthebeard's Avatar
I think what he was getting at was if the insertion tool is not thread specific, then he'll just buy a 1/4-20 kit and use that tool for the 1/4-24 helicoil repair on the case?
IG @eric.the.beard
Old 12-05-2018, 04:39 PM   #8
FredoTwoWheels
I have the helicoil tap for 1/4-24, I just broke the thread installer tool. What I meant was that I would buy a kit and just use that installer tool.
Old 12-05-2018, 05:18 PM   #9
JasonMcElroy
JasonMcElroy's Avatar
If you've got an extra 12-24 screw you can just grind a relief into the end so that it can be used as the installer.
If you grind half of the diameter off the threaded end about 1/8" deep (this is HARD to describe) it will engage the the tang on the coil for insertion. If you look at other installers you can see it better.
Jason
Old 12-05-2018, 08:09 PM   #10
johnjzjz
johnjzjz's Avatar
I was just making you aware of the mistakes others have made
glad you have it under control
Similar Threads
Timing a Shovelhead, help!!! BackPorchChoppers The Board 19 01-29-2017 05:50 PM
Stripped Timing Hole Bolt - Helicoil? odyssey The Board 8 07-01-2013 07:43 PM
8 Hole Tin Primary? KELD The Board 1 06-07-2013 11:28 AM
Stripped out screw head removal tip anitasanger The Board 10 05-02-2013 10:01 AM
stripped bolt hole Concrete B The Board 5 08-03-2011 09:16 PM
