#1 |
We're putting a starter on a 76' sportster and I was curious if the stock sportster starter would work with a stroker motor? Does it have enough balls? Or do I have to suck it up and buy a hi-torque starter?
Sponsored Links | |||
#2 |
ya know, i was thinking about this since you sent me that PM.....i don't think that it'd matter. mind you, i am no pro, and i am on my first Ironhead, but it seems to me that the starter shouldn't have to work any harder with a stroker motor if the compression is still close to stock. if you have upped the compression, i'd say try the one you have...........then maybe get the hi-torque one.
just my .02
if it ain't broke, fix it till it is! |
#3 |
I'll agree, if you have a stock starter try it first. But if you don't have anything to start with, I'd buy the high torque starter to begin with. A lot of early Harley starters were pretty marginal even on stock engines.
#4 | |
Did you get a chance to check out that starter?
#5 |
Moderator
Just so ya know, it takes the stock starter every thing it has to start a stock Ironhead, the same for shovels! so if you modify the motor, you should get the best starter you can, and get a gellcell bat or one of H-D's AGM bats for the amp load, as the acidcore bat will puke acid out of the breather tube when you start the bike!
#6 |
naw, haven't gotten it wired yet. i think im gonna swap frames and finish up that gas tank before i bother wiring anything. truth be told, i rue the day that i have to wire that bike, electrical diagrams and me don't mix!
#7 |
I have a ironhead stroker and a allballs starter doesn't even turn it over !!!
#8 | |
Moderator
![]() Quote:
Roach.
The Road to success is covered by the Backs of Many! I chose the Hard way!!!! ![]() |
#9 |
I have a 96" shovel and a stock starter, unless the timing is way far advanced I dont think there would be a problem. Imo
#10 | |
![]() Quote:
Short answer is yes it will work The standard starter motor is the same as on a big twin so if will spin over a 1200 or 1340 big twin a 74" stroked iron head should be ok However if you are running hi comp pistons it will be at its limit, you will need motor to be in perfect working order and a good battery to make it happen Have 74" stroker kit in my 77 sportster and the standard starter motor starts it ok |
#11 |
There is not much value in comparing starting a big twin and a sportster.
Do you have a already kicker on this Sportster? If so, kick and push the button at the same time. You will be surprised at how well this works. |
#12 | |
![]() Quote:
however if there is logic behind your statement ie primary drive ratios or compression ratios I would be interested in finding out. |
#13 | |
![]() Quote:
Bob |
#14 | |
![]() Quote:
exactly right, on freshly rebuilt motor before it is run in the standard starter motor will struggle, however once motor is run in and friction from new bore / rings has settled down the standard motor will suffice if everything is in order, ie decent gauge starter wires , batter in good nick and starter motor working as it should |
#15 |
#16 |
Moderator
Witithgit.. the shovel pistons are way different than a Ironhead piston.. one of the reasons why sportys will break your leg rather than throw ya over the bars like a shovel will....
Roach.
#17 |
#18 |
Moderator
Have you seen them side by side.. the sporty piston has a very steep angel for the top... think of it sparking before top dead center... the bang hits the front of that hill and pushes the piston backwards Fast!!
Not so bad on a high comp shovel.... Hence why I retard the timing on the sportys..... Roach.
#19 |
that is an inherent fault of a hemi head with hi comp piston, which is why twin plugging is so effective on these types of engines, all of the fuel mixture is being ignited at the same time rather than one side of the cylinder being shielded from an offset sparkplug by the piston crown
#20 |
isn't there a piston porting thread on here or am I remembering it somewhere else?
Display Modes | |
