XL/XR hybrid mutt - The Jockey Journal Board
Old 02-09-2020, 09:57 PM   #1
Sporticus
Sporticus's Avatar
Default XL/XR hybrid mutt
Since I was bashing on the JJ in a recent thread, I thought I should contribute something. This is a project not typical of the JJ, but I hope you find it interesting. I've posted in an another forum already, so this may be a repeat for some of you.
I started with an '81 Sportster. It now has Ceriani/Yamaha forks, wheels, and brakes and an 18" rear wheel. I found a weird stash of parts and had to make it work. Those are XR750/XR1000 heads. The cylinders were homemade a long time ago by a now-deceased machinist I never met. He passed before finishing them (which I have done). They are standard XL or XR1000 dimensions. I'm running unobtanium JE 10.5:1 pistons (meant for an XR1000). The rocker boxes are special. They are completely homemade (not by me), use the XR stud patterns, and have ironhead internals. Genuine XR rocker boxes and internals are way beyond my pay grade. The crank has stock IH flywheels with Evo rods. I had to modify the cases for XR pattern studs.
Since these photos were taken, I'm picking up an aluminum featherbed style tank, a copy of an XR750 oil tank, and don't yet know what to do for a seat. I'm trying to keep people who think they know stuff confused.
The photos below are a VERY rough mockup, so please don't feel the need to tell me what's wrong with it. It's apart now for the 100th time while I assemble the engine, hopefully for the last time.
Sporticus is offline   Reply With Quote
Old 02-10-2020, 07:57 AM   #2
Elektron
Default Re: XL/XR hybrid mutt
Looks like a great flattrack style build. The XR750 style is probably my favorite H-D product. The jugs are round, with wide finning? The fin spacing seems to be much-wider than the OEM head. I'm wondering if that will negatively-impact cooling? The jugs have iron liners, or are they Nikasil-coated? The latter could help to lighten it up.
I ran-into some local guys with a lot of XR750 and XR1000 parts recently, also other vintage H-D OEM parts.
Do I see a Goose big-cubic inch touring bike back-there?
Name:	H-D XR750.01.jpg
ID:	256194   Click image for larger version
Name:	H-D XR750.03.jpg
ID:	256196   Click image for larger version
Name:	H-D XR750.02.jpg
Name:	H-D parts Dania 2020.01.jpg
Elektron is offline   Reply With Quote
Old 02-10-2020, 06:14 PM   #3
Sporticus
Sporticus's Avatar
Thanks Elektron. Yes, that's a Guzzi V11 LeMans. It runs great and does everything I ask of it because I don't mess with it. I change the oil, get it new tires occasionally, and leave it alone. It has never let me down.
I wish I had posted a photo with the rearsets I put a lot of thinking into. Once I get the right bodywork on it, it will hopefully look a lot more vintage roadracer-ish. I don't know about the finning - XRs been that way since 1972. I don't know if the genuine XR cylinders have more finning than these. I never had one in my hand. I got these one-off cylinders as you can see in the photo below. They were rough bored and the relief for the pushrod covers wasn't right. I'm guessing these were destined for an XR1000. The XRs have essentially straight aluminum tube for pushrod covers and don't need as much space as an iron sportster cylinder has. You adjust the clearance through eccentric rocker shafts in the head. I need more space for pushrod covers because I'm using regular ironhead collapsing covers with adjustable tappets.
Nikasil is very cool stuff, as any Guzzi will agree. I'm not sure how to make it work here. The cylinder liner (see photo below) has an integral fire ring - the raised portion on the top. Its an iron liner from LA Sleeves intended for an XR1000 (they still make them). That mates with its female counterpart in the head. No gasket is used. I guess if you made your cylinder from scratch you could incorporate the fire ring into it and Nikasil the cylinder wall. That's all way beyond me.
Old 02-10-2020, 09:07 PM   #4
I can't resist. *Nothing's* wrong with it. Bad-ass and beautiful.
Old 02-10-2020, 10:05 PM   #5
Elektron
One of my friends has a couple of project Sportsters, a '70 and a '76, I believe they are. He has a Low Rider, an '80, 80 cu. inches, he bought new. We're getting ready to go to Daytona next month. I've been on him to do something w/them, at-least they aren't sitting outside rusting into nothingness. I've sent him pics of yours, and the thread link, trying to motivate him. He has an S&S stroker kit, without the jugs, it's currently got the re-located cylinder holes in an OEM pair. I've suggested that he just build the ^$##! engines stock, and to sell-off the S&S parts. At least build one of them, and get the bike going!
Old 02-11-2020, 06:02 AM   #6
Ducbsa
A friend who has raced a Vincent Comet in AHRMA and built motors for others has used these vendors for Nicasil and says it is bulletproof. They should be able to help you.
https://www.millennium-tech.net/serviceInfo.php?id=7
https://www.advancedsleeve.com/power...rts/xr750.html
Ducbsa is offline   Reply With Quote
Old 02-11-2020, 08:36 PM   #7
Sporticus
Sporticus's Avatar
Nikasil has worked very well for Guzzis, though I have heard stories of it peeling off in early bikes. I had a '75 850T and the cylinder walls looked beautiful on it, with no signs of peeling. The only way it work with an XR is if the stock liner wore, but not in place of it. I still needed the stock cast iron liner inside my bare cylinders. Elektron, I'm extremely honored that my mockup photos could inspire your friend. Ratso - thanks for the accolades, but that mockup has a long way to go. I'm picturing the final version with an aluminum Norton Manx style tank and seat. The pipes are going to need some work, and I need to build the transmission right (with the right Andrews gears) so I don't punch a hole in the cases I have put so much time into. I'm already planning on a Barnett Scorpion clutch assembly to not deal with the 1000 cc Sportster clutch shortcomings. My goal is to vintage road race this in the spring, but am building it so it can be made streetable without a ton of work should I realize it sucks on the track or I don't want to risk crashing it after so much work. Here is a similar photo to the earlier ones, but you can see the right homemade rear-set assembly. The stock oil tank is gone, and I'm waiting for a repro XR750 tank to take its place.
Old 02-12-2020, 02:28 AM   #8
thefrenchowl
thefrenchowl's Avatar
It'll be a pig to race this beauty of an engine with this std post 82 frame... They were only designed to go straight, and even that they did not do well... Too long and too heavy...
Plus, does a special café racer has to have Norton Manx tank and seat on it??? The replica KRTT/XRTT tanks and seats are still available for not much more money!!!
But 5 stars for the motor!!!
Patrick
Anyone that can play drums with underwear on their head while wearing a monocle is alright in my book...
https://web.archive.org/web/20071011....com/index.htm
thefrenchowl is offline   Reply With Quote
Old 02-12-2020, 08:09 AM   #9
Sporticus
Sporticus's Avatar
Thanks Patrick. It's an '81 frame - does that make any difference? I'm really hoping the 14" shocks and much shorter forks make it handle a bit less like a freight train. I got in touch with Keenan Tatro of Tatro Machine and he suggested taking an inch out of the front down tubes, which I haven't ruled out yet. Rocker box to frame clearance is very, very limited already, though. I rode it once when it was a bone stock 1981 Sportster. It went nice in a straight line, but that's about it. I thought long and hard - in fact, far too long and hard about the bodywork. I just want to build something I haven't seen before, hence not using XRTT or KRTT bodywork. Plus, I didn't want it to look like something it's not. I'm not really sure what it is, or how to explain what it is to strangers in 100 words or less. I could talk here for quite a while about exactly what you have to do to "bolt" an XR top on onto a Sportster, and this isn't a 100% XR top end.
Patrick
Old 02-12-2020, 12:52 PM   #10
thefrenchowl
1981, you're right, I did not notice at 1st the front steering casting!!!
But any Sportster frames XLH post 67 and XLCH post 1970 are too long and getting heavier year by year...
On the KRTT/XRTT look, me thinks the Norton Café look has been way more over done in the past!!!
But that's just me, probably been living far too long in GB to have any sympathy left with that scheme!!!
You say you're using iron head internals... You could do worse than try to fit early EVO Sportster crank and rods, that will save you one inch in cylinder height, not negligible on such a tall alloy head set up... (XR 1000 rods could be said to be Evo prototype rods and were 1" shorter than their iron head sisters...)
Patrick
Old 02-12-2020, 08:19 PM   #11
Sporticus
Sporticus's Avatar
I should have mentioned the crank. I'm using ironhead flywheels and Evo rods, which as you mention are the same length as XR1000 rods. Same crankpin diameter, just 6.926" center to center as compared to the ironhead 7.4375". Otherwise my pistons and heads would become close friends real fast. My friend who does this for a living is assembling the flywheels and rods and truing and balancing them. I'm waiting for that to be done before I can finally assemble the bottom end. Never tell someone you're in no rush. The cams are Red Shift 505 - Red Shift puts new lobes on your old shafts and gears. They were happy to orient my XL lobes in XR fashion. I didn't realize just how much material I would have to remove from the right case for those cams to fit. An old timer at Red Shift said that 1977 and up ironheads can't accommodate much larger than the stock Q cams. He sent me photos of cases they had clearanced (on a mill, of course). This lowered my anxiety amount removing that much material from my own case (done much uglier with a die grinder).
Patrick
Old 02-13-2020, 07:42 PM   #12
Sporticus
Sporticus's Avatar
Patrick's post got me thinking, and then I saw these photos on the interwebs. These photos show an 1980-81 XL frame next to a factory XR750 frame (frame with cast neck is XL). The frames look remarkably similar (including that weird-ass rear section), though the XL is about 15 lbs. fatter. The steering angle difference is also significant: 26.5 degrees for the XR versus 30 degrees for the XL. I'm throwing out a guess here - I'm guessing flat track bikes have more generous rake than road racers. It's a good thing I'm not fast, even on a fast bike. I will look cool, though.
Old 02-21-2020, 12:27 PM   #13
panman27
Hey Sporticus, that's going to be a great looking bike and a lot of fun to ride. I own a 1977 XR750 that I rode in vintage dirt track and it put a grin on my face every time I rode it. I'm currently building a '75 XR and will be building a '61 XLR later this year. 26 degrees has always been kind of a universal fork rake for dirt track bike. Modern racers start around there but have adjust triple trees to put a little fork rake in or take a little out. My XR frame was a stock frame with stock rake but the swingarm position has been modified. Worked great for me. You can rake that stock sporty frame easily enough by putting a V cut in the top tube just behind the neck casting and slightly shortening the front down tubes, then you heat 2 tubes with a torch and pull out easy to mate up again. Leave the engine and engine plates in and bolted up so cradle doesn't move. If you want more info on doing contact me. I was a nuke certified high pressure welder and I've done dozens of street and race frames. Question about the engine build...you say you're using sporty rockers? are they stock geometry? are the shafts you're using stock sporty shafts? Were the rockers carved from billet or are they a high modified stock rocker? don't look like it. Ron
panman27 is offline   Reply With Quote
Old 02-22-2020, 10:40 PM   #14
Sporticus
Sporticus's Avatar
Thanks. The rocker boxes were made from scratch by the guy I bought the heads and cylinders from. He put a huge amount of work into them. I can see there was a lot of welding and grinding involved. They use stock ironhead rocker arms and shafts, so you still have to adjust the clearance ironhead style, with adjustable tappets and collapsing pushrod tubes. I've thought a lot about using the stock rockers with the XR valve angle versus the XL valve angle. I'll just get it running and worry about that later. Thanks for the de-raking info. I was planning to take an inch out of each downtube but hadn't thought of cutting a V out of the top tube first. What do you use to fill the V? Another (short) section of tube cut in half lengthwise?
These boxes don't look much like XR boxes. The top of each box is 1/4" aluminum and is removeable. Never mind my Sharpie art.
Old 02-23-2020, 11:43 AM   #15
panman27
Yeah those rocker boxes are something, a lot of work to get right. Yes I would fill V on top tube with another pie cut V piece cut from a matching tube. Make sure you bevel all tubes to be welded to get 100% penetration. If you have heli arc or know someone with a TIG welder it's nice to use that on the root with about a 1/16 root opening. I never slug the inside of the tube but I TIG weld 100% and as I said I am a cert. high pressure welder. If you're worried about your weld on top tube you can grind weld flush and then take a piece of 1/8" 1 ro 1 1/2 strap and bend around tube to cover weld and weld to reinforce. If you leave a little of the tube at the bottom when you cut the V you can heat with torch when you bend to keep the tube in place. Also if you tack a piece of 1" strap at 3 o'clock and 9 o'clock on the rear part of the v'd tube it will help to keep it aligned straight and then tack to the other side of the tube to hold alignment after you bend.
Old 02-23-2020, 12:45 PM   #16
thefrenchowl
Me thinks, to make the 81 frame right would also require setting the steering about 2" backward to bring it near to XR/XRTT wheelbase...
The 81frame gives about 61" wheelbase, way too long for any sort of racing apart from Salt Flats or drag strips...
Great rocker boxes no doubts, PO knew what he was doin', but like Panman, I wonder if he thought long and hard about the rocker geometry... That geometry is bad enough on a street Sporty, and acceptable there, but XR rocker geometry is tighter due to shallower valve angle and if I remember right, H-D had 2 std XR dies to forge them, then they were machined then cut and rewelded in 4 different jigs to give each rocker its specific angle for maximum leverage and minimum wear...
Patrick
Old 02-24-2020, 07:57 AM   #17
Sporticus
Sporticus's Avatar
Regarding the frame, based on a bunch of things, I'm sending my frame off to have the cast area removed, and reworked XR style with 26 degrees of rake and a lower neck. It'll handle much less like a dump truck and lose a bunch of weight. It was my wife who begged me to spend the money because she fears how pissed off I'll be if I fuck it up (meaning the end result is less than perfect) and I've got an arm injury that won't heal because I keep using/abusing it. I hate to wait but it'll be worth it.
The rockers are what they are. Someone very knowledgeable suggested cutting them and rewelding at particular angle (can't remember what that angle was). That's a longer term sub-project, and I'll start gathering more ironhead rockers than I need to do this right.
Thanks for the suggestions.
Old 02-24-2020, 05:25 PM   #18
thefrenchowl
Hi, Sporticus.
Extract from OEM XR factory blueprint showing rocker geometry for the front cylinder, should help you get the rocker angles you need to check... Scale can be derived from cylinder bore (OEM blueprint is scale 1/1)
Patrick
Old 02-24-2020, 10:23 PM   #19
Sporticus
Sporticus's Avatar
Thank you Patrick! I went to save this, and realized I already had it in the dark recesses of my computer but had completely forgotten about it. The rockers won't be my next sub-project, but will be up soon.
Old 02-25-2020, 12:11 PM   #20
Apehanger Hank
Apehanger Hank's Avatar
Great project. I look forward to seeing it finished!
The opinions of this person are sought after by rock stars and mental patients all over the world!
Apehanger Hank is offline   Reply With Quote
