Hard Case Saddlebag on Rigid Frame - Page 2 - The Jockey Journal Board
Old 03-28-2019, 09:32 PM   #21
FredoTwoWheels
FredoTwoWheels's Avatar
Default Re: Hard Case Saddlebag on Rigid Frame
So here's where we are at. I realized I could just use old fender mounts, which I had two of, and I dont plan to carry too much weight, so just the two should do. I originally mounted it too far forward and it made the seated position way uncomfortable, so I had to move it back. I now have to plug the two extra holes somehow, probably just going to put a short bolt and washer through and call it a day. I'll probably put some heavy books in it and ride for a week or so before I trust my laptop and tools in it, but I'm happy I at least have the option now!
ID:	254114   Click image for larger version
ID:	254116   Click image for larger version
ID:	254120   Click image for larger version
VL SPRING SHIELD WANTED
IG: PineboxRecording
FredoTwoWheels is offline   Reply With Quote
Old 03-28-2019, 09:36 PM   #22
There we go! Looks sturdy
Old 03-28-2019, 09:42 PM   #23
Simple and effective. Good job Fredo.
Old 03-28-2019, 09:55 PM   #24
HD48FL
That works, nice job.
Old 03-29-2019, 03:31 PM   #25
TATER
TATER's Avatar
Whats the story with the tape ?
Why dont you ship heads and cylinders in an old helmet ? They might actually survive the gentle and loving handling of UPS/FedX.
TATER is offline   Reply With Quote
Old 03-29-2019, 03:53 PM   #26
HD48FL
Maybe holes and he's trying to keep any potential water out?
Old 03-29-2019, 06:20 PM   #27
Apehanger Hank
Apehanger Hank's Avatar
Good job!
The opinions of this person are sought after by rock stars and mental patients all over the world!
Apehanger Hank is offline   Reply With Quote
Old 03-30-2019, 10:07 AM   #28
FredoTwoWheels
It's just to cover the first mounting holes I drilled that did not work. I plan to get some short bolts and washers to plug those up with after I test this out for a bit and make sure it will work.
Old 03-31-2019, 09:39 AM   #29
TATER
TATER's Avatar
I have patched quite a few sportbike fairings together with plastic epoxy.
Find out what type of material the Pelican is made of and match up to that.
Tape is already on one side so flip up the backside and pour into hole. May need to rough up the surface to get epoxy to fuse well.
Might need to countersink each side a bit to form a plug that wont pop out of either side.
Old 03-31-2019, 09:43 AM   #30
TATER
TATER's Avatar
Copied from pelican website
What adhesives and/or paints can be used on the cases?
Due to the nature of the polypropylene being chemically inert, very little will attack the material. That also means that very few adhesives and paints will adhere satisfactorily. For an adhesive, we have found that 3M’s DP-8005 two-part adhesive works very well with our case material. It has also been reported that “Shoe Goo” works very well. For paint, Krylon has a product out called Fusion that they claim will adhere to polyolefin-based materials like polypropylene.
Yep, poly is a bitch to glue. Good luck. Might give black silicone a shot.
Old 03-31-2019, 06:28 PM   #31
farmall
Polypropylene welding has been common for decades. My wife used to weld ABS and other sportbike bodywork similarly. Identify your plastic by recycling symbol
https://learn.eartheasy.com/site-fil...30479243-5.jpg
then order appropriate filler rod.
https://www.kingplastic.com/tips-for...hermoplastics/
Practice on scrap first if possible as with any other welding process.
farmall is offline   Reply With Quote
Similar Threads
Fxr drivetrain 96" Twinkie drivetrain Softail and rigid frame Okiecockfighter Parts For Sale 2 12-22-2012 08:33 AM
Panhead Springer/Titled rigid shovel frame 83shuvluv Parts For Sale 5 09-19-2012 01:42 PM
Parting Out Rigid Roller, Killer AEE Frame, Wheel Specialties Springer, etc.+pics... terd ferguson Parts For Sale 6 02-28-2011 05:06 PM
Triumph Rigid gearbox case and mounts bdavanza Wanted 0 02-13-2011 06:40 PM
Fitting Delkron cases in paugho rigid frame Metal Meltdown The Board 10 06-17-2006 11:39 PM
