The hole that holds my magneto secure is stripped. I have some 1/4-24 helicoils, but no insertion tool and I need to get up and running quick. Would I be better off drilling it and tapping it for 5/16 or should I attempt the helicoil without the tool? How much meat is surrounding that area in the case?
VL SPRING SHIELD WANTED IG: PineboxRecording |
make an insertion tool? they're pretty basic.
Do you have the tap? Proper Helicoil taps are not necessarily standard threads and usually come in the kit. An insertion too should be easy to make.
any 1/4 inch insertion tool is the same its not thread specific like the tap
seen many made 5/16 to repair second or third time maybe - what we did was drill and tap the 5/16 to 1/4 X 24 double nut the stud we make from a bolt and install it back to original - welding is the other way
Ineptocracy (in-ep-toc'-ra-cy) - a system of government where the least capable to lead are elected by the least capable of producing, and where the members of society least likely to sustain themselves or succeed, are rewarded with goods and services paid for by the confiscated wealth of a diminishing number of producers |
It was my understanding I would need an insertion tool of the same thread. I read about making one by sawing a slit in a bolt, but the only 1/4-24 bolt I have is the one for the mag, and I had to order it off ebay they are not easy to find (or were not when I was building the bike) If the tools are not thread specific though, I'll just go buy a 1/4-20 kit and use the tool, thanks guys.
#6 | |
first - you will only end up with a 60 percent thread using a 1/4 X20 tap and we are talking about aluminum - it will strip right out again as it s not deep enough second thing - if you use a 1/4 X 20 tap and that happens = step two - the 1/x4 24 heli coil is also compromised as the course thread 20 is deeper and the 24 thread is considered a fine thread and the coil thread will be shallow not as shallow as with the regular tap BUT <<<<< this is the reason in the end so many have a 5/16 X 18 thread and the bolt head need to be modified to use it on a mag in the end its all effed up and still not right going the easy way your choice - do it right the first time - or what ever happens happens
#7 | |
IG @eric.the.beard |
I have the helicoil tap for 1/4-24, I just broke the thread installer tool. What I meant was that I would buy a kit and just use that installer tool.
If you've got an extra 12-24 screw you can just grind a relief into the end so that it can be used as the installer.
If you grind half of the diameter off the threaded end about 1/8" deep (this is HARD to describe) it will engage the the tang on the coil for insertion. If you look at other installers you can see it better. Jason |
#10 | |
glad you have it under control
Thread | Thread Starter | Forum | Replies | Last Post |
Timing a Shovelhead, help!!! | BackPorchChoppers | The Board | 19 | 01-29-2017 05:50 PM |
Stripped Timing Hole Bolt - Helicoil? | odyssey | The Board | 8 | 07-01-2013 07:43 PM |
8 Hole Tin Primary? | KELD | The Board | 1 | 06-07-2013 11:28 AM |
Stripped out screw head removal tip | anitasanger | The Board | 10 | 05-02-2013 10:01 AM |
stripped bolt hole | Concrete B | The Board | 5 | 08-03-2011 09:16 PM |
