Thread Tools | Search this Thread | Display Modes |
#1 |
Hello,
I just bought a 72 Triumph Bonneville 650 engine. It has an open crank ventilation; open into the transmission that is. I am not used to this since I only wrenched 69 and earlier before. I mounted a new alternator stator. I wanted to make sure everything was alright so I ran the engine without the transmission cover for about 5 minutes. During this, almost a pint of engine oil came through and out on the ground. This seems a little excessive to me, but I don’t know what to expect. Do I need to tear the motor apart in search of a fault, or might this be considered normal? Best |
Sponsored Links | |||
#2 |
'open into the transmission' ? , do you mean primary chain side.
#3 |
Yes, into the primary chain side, sorry.
And I ran it without the chain case cover... Last edited by tgb3040; 10-02-2013 at 03:13 AM. |
#4 |
It's normal. There's no seal on the crank on the later models, there are also a few small breather/oil return holes (I believe).
The primary and engine share the same oil.
When people who should have known better cautioned me about the dangers of motorcycle racing I told them that a fear of death is nothing more than a fear of life in disguise. |
#5 |
Those motorsrun without a drive side oil seal to share engine oil with the primary. tere are three small drillings to allow the oil to drain back to the sum at a certain level. Run with the primary open &it's going to end up on the floor.
#6 |
a pint sounds like a heck of a lot but then a little oil does appear to go a long way. Not saying that there is a problem but i'd just look to make sure there was a good oil return in the tank.
#7 |
Yes, I am starting to think: oil pump.
Now I can't get the motor started to check the return flow. I have a spark and I have fuel, so this indicates to me oil in the crank case. I have good oil pressure, but the non return valve in the return piston might be leaking... That would give me these symptoms. Hmmm, now, of to work. |
#8 |
Emptied the crank case, got the motor started, good return flow, no problem there. Not nearly as much drainage this time as the last. So things are good. Thanks everybody.
Best |
Display Modes | |
