#1 |
Been looking at getting a sportster for a while now and came across this 1986 sportster that I just had to have
![]() It didn't run when I went and looked at it and it had been sitting outside for a few years (I think he said 8) so you can imagine that it's pretty crusty. He said that he couldn't get it started but didn't really know what was going on with it. there was a few different harley ignitions in the box of spare parts that he gave me with it, so it looks as if he was trying to chase the problem there. Oh well, we'll figure that out later. I'm not sure that I feel as if he should really have been working on a bike like this in the first place. As of right now, the plan is to get it in a running condition, just to be sure that it does, and then once that's squared away, it will be taken apart completely to be cleaned up. I think this time around I would like to make it look sort of like an older sportster while keeping some of the later parts. I am sure some of the period correctors won't be super psyched on it, but whatever. Here are some pictures of it's current state Loaded up ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Dyna ignition etc just because ![]() also the tank was rusting from the inside so it's trashed. I had this laying around so I'm going to go ahead and use it. Also switched out the bars with some XLX (I believe) bars that were laying around ![]() ![]() ![]() |
Sponsored Links | |||
#2 | |
![]() Quote:
I am extremely confused by that!! RP
If it Aint a H-D and it Aint from '66 to '84
I might be Guessing!!! ![]() |
#3 |
Moderator
86 is the first year for the Evo Sporty, so that one just might be one of the last late 85's sold as a 86.....
The Road to success is covered by the Backs of Many! I chose the Hard way!!!! ![]() |
#4 |
Ah, too bad I didn't see this sooner, could have just told you we already verified that it was, in fact, a true 1985
![]() Well, instead of messing around with that butterfly carb, I took the money that I made from selling my KZ440 this weekend and bought a Super E first thing this morning. Put it on and with the help from my dad fixed some wiring that had been sort of hacked up off of the battery to the ignition and we got it fired right up http://www.youtube.com/watch?v=0sMh3IOXCX4 Now starts the tear down.. |
#5 |
Moderator
Nice Job!!!
#6 |
And don't even get me started on the case race......
#7 |
Well now that its up and running the entire thing will be taken apart to be gone over and basically rebuilt
#8 |
well my dad did dig up these old .030 pistons he had from 25 years ago. so I will use these. red shift cams will also definitely be used
![]() also, no more kawis unfortunately. but there is an 89 FL with a full twin cam drive train for sale. but I'm sure that interests nobody here haha |
#9 |
I believe it's V-Twin that makes the upgraded alternator with the magnets incased.....
#10 |
Minor hi jack here.
Jesse do you have any stroker flyweels and pistons laying around? You can pm me if you like. |
#11 |
Moderator
That a Rhetorical ????
The Road to success is covered by the Backs of Many! I chose the Hard way!!!! ![]() Last edited by Dragstews; 05-30-2013 at 07:55 PM. |
#12 |
Those ads are pretty cool there. The pistons are actually TRW though
#13 |
Guilty,
I am sure you already know this but: If you go with the Larger Intake ( 1 15/16" ) your valve to piston clearance will need to be checked, post 70 OEM pistons had a factory relief milled into the intake crown side of the piston for additional clearance even with stock P cams |
#14 |
Yep that's been accounted for
#15 |
Took the top end partially apart tonight, and found this
![]() just kidding, that's from my dad's old fxr ![]() ![]() ![]() ![]() ![]() Last edited by guiltyview; 05-31-2013 at 09:01 PM. |
#16 |
hey !! that is how my ironhead project started umm almost 2 years ago ... save those rollers for me Jesse I am gunna pick them up since I have nothing better to do !!
sorry been drinking in the shop again. I may regret this post and pressing in my bearings into my trock door and fine fitting it tonight .. then again maybe not! |
#17 |
So I got it ripped apart yesterday a little more yesterday. Everything is still looking pretty healthy despite the exterior
![]() ![]() ![]() ![]() These are the wheels I'll be using. My dad laced them up 25 years ago to be used on one of his projects that he didn't end up getting to. New tires and all ready to go ![]() ![]() ![]() ![]() ![]() ![]() Last edited by guiltyview; 08-14-2013 at 11:06 PM. |
#18 |
got the bottom end broken apart tonight and cleaned it up just a little. still no surprises luckily
![]() all of the magnets seem to be in great condition ![]() sait it in the parts washer and scrubbed it down really quick to get the heavy shit off. I think it will clean up pretty good ![]() ![]() ![]() hopefully some actual fun stuff to follow |
#19 |
the only pro flow that I know of is attatched to a big twin cutaway here
I'd like to start cleaning the cases a little bit. any ideas of what I should use to get all of the yellowing/stains out? Seems to be in there pretty good ![]() ![]() Last edited by guiltyview; 08-14-2013 at 11:08 PM. |
#20 |
Everyone here is actually strongly against glass beading as much as possible because it just impregnates itself into the cast aluminum. It's impossible to get it all out and when you run the engine, the oil heats everything up causing it to expand, which brings it out. Then incomes the nightmares. Have had a few come around here completely trashed because of it
Display Modes | |
