Retorqued heads and bikes now running awful - The Jockey Journal Board
Old 09-12-2020, 02:03 PM   #1
Default Retorqued heads and bikes now running awful
Evening all!
After my ride last weekend it was time to tighten everything. I retorqued the heads, front was good, rear needed a little more.
Now, upon doing this, and since I did the bike is idling really rough, coughing through the carb etc. The bike revs and picks up freely but idles terribly?
I'm really stumped. 3 of the bolts torqued down and it's gone from running superbly to terribly.
Any input welcome!
King or street sweeper, everbody dances with the grim reaper.
Old 09-13-2020, 01:58 AM   #2
dbkp
dbkp's Avatar
Default Re: Retorqued heads and bikes now running awful
I don't know how much torqueing you did, but years ago I had this issue, and ended up re adjusting the pushrods.
" And there was Old Sneep, sucking on a lemon"
Old 09-13-2020, 03:43 AM   #3
Thunderbird
push rods, disturbed inlet manifold.
Thunderbird is offline   Reply With Quote
Old 09-13-2020, 03:47 AM   #4
DB!
I hadn't thought about that, could be theyy're a little tight!
Old 09-14-2020, 04:17 PM   #5
Jockeyshift41
Jockeyshift41's Avatar
Anytime I re torque heads and cylinders, if I get movement, I check and adjust pushrods/tappets. I also use a o ring intake from a pan with adapters and check the clamps often.
Al SuicideShift : separates the men from the boys
Jockeyshift41 is offline   Reply With Quote
Old 09-14-2020, 05:21 PM   #6
Thanks for the input man! yeah I checked pushrods, all real good. I gave the plumber nuts a tiny pinch up and it's running like a champ again!
Old 09-14-2020, 11:51 PM   #7
Wow, it surprises me how sensitive the knucklehead is to small changes!
Old 09-15-2020, 04:43 AM   #8
Yeah, it's a real sensitive soul. It's the same with carb adjustment as well.
My flatty, you could get it to run well on varied settings if you wanted to fart about with it. I caught the HS needle on this M35 with my hand putting my fuel on and moved 5? clicks maybe richer, bike was running like I'd put diesel in it.
Of course, It's why a lot of folks put an M74B on them, with the fixed jet it's less precious.
Old 09-15-2020, 05:19 AM   #9
At least you've stopped calling it 'she' ....
Old 09-15-2020, 05:52 AM   #10
Haha! what's wrong with that!??
The bikes name is 'Snake Charmer' but if I referred to "HER" as that people would frown!!
Old 09-15-2020, 11:57 AM   #11
To my eyes. . .
If valve lash is set in thousands of an inch, then changing the stack height of the cylinder and head assembly by re-torquing the head bolts would definitely have a noticeable effect.
Old 09-15-2020, 01:02 PM   #12
Originally Posted by JasonMcElroy View Post
To my eyes. . .
To piggyback on that, this is why I always loosen the top motor mount before a retorque.
Old 09-15-2020, 01:58 PM   #13
Yeah I loosened it all off. We're back to running good today. The rear plug was running a little lean, turns out the retorque sorted it!
Running and riding great. 25 tooth was the best thing I've ever done.
Old 09-15-2020, 05:19 PM   #14
To my eyes. . .
Makes good sense, guess I'll have to be more cognisant of that on my next re-torque although I do check valve lash. Good reminder.
