foot or hand shafter drum - The Jockey Journal Board
Old 04-20-2019, 12:35 PM   #1
harleybrad
Default foot or hand shafter drum
Converting my 52 Pan to a jockey side shift, really don't want to pay for a hand shift drum and have a hand cover. So was wondering if the foot drum would work without the ratchet top.
harleybrad is offline   Reply With Quote
Old 04-20-2019, 03:15 PM   #2
Default Re: foot or hand shafter drum
a hand drum would be difficult to use as the throw is very short
most use a ratchet selector with a FX drum as its to the rear to up shift and yes the FX is the one every one wants and it has become expensive, as in 3 to 1 in the cost of an FL drum
Old 04-20-2019, 07:15 PM   #3
harleybrad
thanks for the reply, but I think I need to be clearer, I would like to put a 54 FLH foot shift drum , in a hand shifter lid. I'm thinking it will work, but might be hard to find neutral.
Old 04-20-2019, 09:45 PM   #4
Are you using a tank gate or just hand shift?
Old 04-21-2019, 09:43 AM   #5
You can file or grind the neutral detent groove deeper on the drum cam.
Old 04-21-2019, 01:49 PM   #6
the timing and the travel length is different
But that is something I never tried i will look as I have both
Old 04-21-2019, 07:14 PM   #7
harleybrad
jockey side shift, back in the day I could find neutral between each gear, when the bitch would move at a stop light, but not sure with the foot cam, never though about the filing , thanks for the reply.
Old 04-22-2019, 12:02 PM   #8
That is the reason I brought up the filing, as that is another trick to file in the false neutrals in a tank top shifter drum. Aaaaaaa am I dating myself?
Old 04-22-2019, 12:19 PM   #9
Couple of hints on riding a hand shift.
When you need to turn left from a stop, do it don't f around.
When you come to a stop, as you roll the last few inches turn the front end to the left slightly. You will always land on your right foot.
If you are a rear brake only rider use the above and get real fast at moving your right foot from the brake or find neutral.
Old 04-22-2019, 08:42 PM   #10
harleybrad
one more, never try to stop on a hill, I don't care what the slope..unless you have a front brake....good words to LIVE bye.......Thanks for the info guys, think I will get out the file.
Old 04-22-2019, 08:57 PM   #11
Just use the bumper of the car behind you to rest up until its time to pull away.
Old 04-23-2019, 04:32 PM   #12
If not a long bike and no front brake turn sideways on the hill, I used to try to always do the turn to the left. I figured out it was way easier to run a front brake.
Old 04-23-2019, 04:36 PM   #13
or always ride with a bud with brakes who will act as you bump stop with his front against your back wheel.
Similar Threads
Juice brake backing plate alignment to drum + axle ericthebeard The Board 5 02-19-2018 03:24 PM
juice drum master cylinder mattressking The Board 3 07-12-2016 06:12 PM
Juice drum rear with foot and hand levers? shovelinit The Board 16 01-09-2016 07:02 PM
Please educate me on Invader drum hub differences dan74 The Board 0 09-01-2014 01:01 PM
8" Triumph Pre-Unit Single Sided Front Hub & Brake Drum or Complete Front Wheel whittiger650 Wanted 3 03-26-2013 06:42 PM
