Home made workshop tools - Page 8 - The Jockey Journal Board
Old 03-02-2011, 08:36 AM   #141
bdavanza
bdavanza's Avatar
Here is a basic valve spring compressor made from a C clamp and a socket with a window cut into it. It works on Triumph heads, at least. The other tool is a 9/16 deep socket with 2 flats ground into it so you can fit a wrench. This with a thin flat blade screwdriver makes clutch adjustments on Triumphs easy and it's still a good socket.
bdavanza is offline   Reply With Quote
Old 03-02-2011, 12:23 PM   #142
flat screwd
flat screwd's Avatar
A few home made items
Belt sander.
English wheel.
Tube bender
Radius brake for sheet metal.
Torch pattern cutter. I cant take credit for this but it is home made and works great.
flat screwd is offline   Reply With Quote
Old 05-07-2011, 02:47 PM   #143
Dan Boy
Dan Boy's Avatar
So this is not so much as a workshop tool, more like a workshop tip. I got fed up with having trouble filling up my battery to the correct mark using a funnel. It was too easy to over fill it.
Now what I do is I have a bottle of battery water with a tight fitting tube through the top to the bottom of the bottle. That way I just need to place the other end of the tube in the battery cell and squeeze the bottle to deliver the water till it gets to the max level and then just stop squeezing and it stops immediately. But maybe you guys already do this!
Cheers Dan.
https://www.jockeyjournal.com/forum/signaturepics/sigpic21807_5.gif
Blown Triple Build
Dan Boy is offline   Reply With Quote
Old 05-07-2011, 03:00 PM   #144
rimirilar
rimirilar's Avatar
That furnace fan is cool as hell. My dad has one in his garage, just not with a rad face on it.
Beacoup Dien-Cai-Dau
rimirilar is offline   Reply With Quote
Old 05-29-2011, 12:58 PM   #145
NRchopshop
NRchopshop's Avatar
spoke wrench. got tired of busting my knuckles because i didnt have any leaverage
lots of nothing
http://el-dorito.blogspot.com/
NRchopshop is offline   Reply With Quote
Old 05-29-2011, 01:09 PM   #146
Dan Boy
Dan Boy's Avatar
^ that is so great I just pissed my self laughing. Nice job. I think you should call it a screwenth!
Cheers Dan.
Blown Triple Build
Old 05-29-2011, 01:16 PM   #147
drainsurgeon
drainsurgeon's Avatar
This thread is great. Keep em' coming.... I'm not as resourceful as you guys.
drainsurgeon is offline   Reply With Quote
Old 06-04-2011, 07:46 PM   #148
gapwelder
gapwelder's Avatar
Stole this idea from somewhere....Tubing notcher attachment for lathe:
gapwelder is offline   Reply With Quote
Old 06-05-2011, 04:03 AM   #149
knuckleworks
knuckleworks's Avatar
thats great any more pics of it??
Lex Talionis
Old 06-05-2011, 09:53 AM   #150
mikeyfrombc
i build a similar set-up for my lathe yrs back , does the job well
DEMON PRECISION PRODUCTS
Custom Machining & Fabrication
mikeyfrombc is offline   Reply With Quote
Old 06-05-2011, 10:59 AM   #151
DANGER
DANGER's Avatar
BBQ fork forged from a 9/16" wrench.
Name:	9:16%22 BBQ fork.jpg
http://dillonsculpture.tumblr.com/
Instagram - DillonSculpture
DANGER is offline   Reply With Quote
Old 06-05-2011, 12:47 PM   #152
Chevota
Chevota's Avatar
Quickly made triumph gear puller.... it works.
ID:	64059   Click image for larger version
ID:	64060   Click image for larger version
Chevota is offline   Reply With Quote
Old 07-22-2011, 08:18 AM   #153
Technically a tool, even if it's disposable.
I've seen too many people baffled by setting up ignition timing over the years, playing all sorts of games with measuring piston movement and using specialty timing plugs and crazy schemes.
I find a part that rotates with the crank and do it the easy way. Fuck trying to figure out cryptic timing wheel marks or getting oil in the face.
If you don't have a degree wheel, you can make one in two minutes with a sheet of paper.
www.youtube.com/watch?v=P4QLXhlozBk
Old 07-22-2011, 12:23 PM   #154
Dan Boy
Dan Boy's Avatar
Nice job, I love it when guys can use some basic methods to do something technical like that.
Cheers Dan.
Blown Triple Build
Old 07-22-2011, 06:56 PM   #155
TikiTodd
TikiTodd's Avatar
Love the screwench, I'm gonna do one up tonight...
TikiTodd is offline   Reply With Quote
Old 10-24-2011, 02:05 PM   #156
billyfly
billyfly's Avatar
my frame jig
billyfly is offline   Reply With Quote
Old 10-24-2011, 05:10 PM   #157
Deadbird
Deadbird's Avatar
Originally Posted by billyfly View Post
my frame jig
Wow. That's pretty cool. Almost looks like you could break it down to store it if needed.
Deadbird is offline   Reply With Quote
Old 10-27-2011, 05:41 PM   #158
Phlogisticated
Phlogisticated's Avatar
Awright, I'll play.
Not because I'm any good at this, but I thought this was kinda funny:
So, I'm taking apart my '47 WL motor & I get to the lifter blocks. I know enough not to use a screw driver to try to pry 'em out, & all my hammers were out getting calibrated, so I was stuck. I puzzled for a while & came up with this nifty little tool to pull 'em out. Worked like a dream! I was pretty proud of myself - I got 'em out cleanly & didn't even wreck anything expensive!
Imagine my chagrin a few days later when I'm paging through the catalog of a commonly known supplier of vintage H-D stuff & there right before my eyes was a tool exactly like the one I made! Well, OK, the one in the catalog was much nicer than mine & prolly worked much better, but imagine the surprise I felt to see that someone else had thought of this already!
Ah, well, I thought it was kinda funny, me thinkin I was so clever & all...
Speaking of being clever, let's see if I'm clever enough to post a pic...
Hmm, apparently I'm clever enough to attach a pic, but not clever enough to resize it down from ginormous. My apologies, I'll work on that.
Phlogisticated is offline   Reply With Quote
Old 10-31-2011, 08:56 AM   #159
supercrouton
supercrouton's Avatar
I made this simple tool to be able to remove these after-market rocker box covers, and adjust the valves, without having to take the gas tank or carbs off. Sure, I could have just bought a 30mm wrench, but I had this 30mm socket lying around that I had to modify (destroy) to work on a BMW back in the day anyhow. This simple tool is also much lighter than its store-bought counterpart, so would be better to carry in a tool roll too. And there is enough left of the socket to make two or three more, if need be, since this one will go with the bike to its new owner. When finished, I also zinc-plated it for durability.
Cheers, Dan.
If you were to take out someone's small intestines, and stretch it all the way out end to end, you'd go to jail.
Angry Monkey Motorcycles official website
supercrouton is offline   Reply With Quote
Old 10-31-2011, 02:38 PM   #160
Dan Boy
Dan Boy's Avatar
Now that's real pro, not only did you make a tool but you went and got it chromed as well!
D.
Blown Triple Build
