H-D Flywheels for sidehack question - The Jockey Journal Board
Closed Thread
Old 09-22-2012, 04:18 PM   #1
Cotten
Default H-D Flywheels for sidehack question
Seriously Folks,
This is the only forum where I can bring this question up.
As a sidehacker, I need 'stored torque'.
In other words, heavy flywheels. Very heavy.
My S&S 4.5" wheels are far too light.
Some of you may not understand, but they are not worth burning up clutches.
T&O's are fantastic, and I have assembled my share.
But I already spent my money on these S&Ss (somewhere around 1975). And perhaps I desire more mass than even T&Os....
Machining a ring to add mass to the S&S wheels shouldn't be much of a problem, since there is plenty of room in the cases.
So here is my question:
Where can I get a piece of depleted uranium to carve a ring from?
Just askin.
Thanks in advance,
....Cotten
Cotten is offline
Old 09-22-2012, 04:34 PM   #2
Cosmo
Default Re: H-D Flywheels for sidehack question
....Cotten
A.Q.Khan??
Might be a bit dangerous to ask, however...
Cosmo
Cosmo is offline
Old 09-22-2012, 04:51 PM   #3
el diablo
el diablo's Avatar
try to hook up with an aircraft maintenance man
they will have materials like that
also strange kinds of strong alu that wheigh more than you would suspect
probl. better to make a ring out of that ....?!!
el diablo is offline
Old 09-22-2012, 06:10 PM   #4
FearNoEvo
FearNoEvo's Avatar
Tungsten carbide, it isn't cheap, and is heavy as heck with almost twice the density of steel, .32 lbs/ cubic inch vs .54 lbs per cubic inch
FearNoEvo is offline
Old 09-22-2012, 07:00 PM   #5
Destralo Roach
Moderator
Destralo Roach's Avatar
Try the stuff that has replaced lead in Duck shot, not the steel shot, it is allmost as heavy as lead......Roach.
Destralo Roach is offline
Old 09-22-2012, 07:01 PM   #6
old.wrench
old.wrench's Avatar
Cotten, if you're really serious about adding mass, forget about the depleted uranium and just drill a few black holes in the flywheels instead.
"it ain't rocket surgery"
"hony swacky mally asbestos"
old.wrench is offline
Old 09-23-2012, 08:44 AM   #7
Cotten
I guess this was not the forum to ask upon, after all.
.....Cotten
Cotten is offline
Old 09-23-2012, 08:48 AM   #8
kickstarts
kickstarts's Avatar
What about Tungsten?
I know it's pretty dense and heavy but I don't know enough about it to talk sensibly.
Real tomato ketchup, Eddie?
kickstarts is offline
Old 09-23-2012, 09:42 AM   #9
Ducbsa
Car guys use Mallory metal , which I think is tungsten, to add weight to balance cranks. http://www.race-mart.com/Heavy-Mallo...al_c_8041.html
Ducbsa is offline
Old 09-23-2012, 09:44 AM   #10
Larry T
Larry T's Avatar
Cotten,
Most of the "hot rod" guys around here use Mallory Metal to add weight to flywheels when they change them from external to internal balancing, so you might check that.
The thing is, you're gonna pay more for any heavy metal than a new set of T & O flywheels would cost. Then you have your labor making everything work. Definately not the economical way to go, but I guess if the point is "look what I did" it might be worth it.
My old Panhead build: https://www.jockeyjournal.com/forum/s...ead.php?t=9455
Occasionally updated Knucklehead project: https://www.jockeyjournal.com/forum/a...p?albumid=3625
Larry T is offline
Old 09-23-2012, 12:27 PM   #11
el diablo
el diablo's Avatar
.....Cotten
why ??
because the answer you wanted to hear didn't came
lots of great tips here to look into
or just buy different flywheels ...its just that simple
Old 09-23-2012, 02:02 PM   #12
Cotten
Folks,
None of your suggestions are available in a 8.5" disc a half-inch thick.
(I have found no 'aluminum' of density even equal to cast iron.)
I already explained in my first post that I want more than T&Os.
There has to be some decommissioned armor somewhere in reach.
....Cotten
Cotten is offline
Old 09-23-2012, 02:35 PM   #13
el diablo
el diablo's Avatar
Folks,
....Cotten
i hope to speak with this guy i know ,who is the head maintenance engineer over at KLM
they have big lumps of alu who are being used to made aircraft wheels ,engine parts ,pump and hydrolic parts for huge airplaines
sometimes he brings leftovers to our shop and there is a friend of us who made a custom set of engine cases and flywheels out of this material for a dragracer that he is racing for over two years now
if its suitable for a 747 and dragracing flywheels ...why shouldn't it work for your flywheels ...
i'm sure he can give me the name for this kind of aluminium they are using
Old 09-23-2012, 02:59 PM   #14
FearNoEvo
FearNoEvo's Avatar
Aluminum as racing flywheels, is used for the purpose of reducing rotating weight. There is no aluminum that matches the density of steel. 2021 is a very common aluminum alloy for aircraft
Re my suggestion to use tungsten, I meant in the way it is used for balancing, drill holes radially around your flywheels and install tungsten plugs.
For instance, if you drilled 20 half inch holes at a half inch deep, radially around your flywheels, both pieces, you would be removing approximately 1.25 pounds of rotating weight from the wheels. Now if you fill those holes back up with tungsten carbide, you would be adding back about 2.12 lbs. A net gain of about a pound of rotating weight.
Double the hole depth, double the increase.
Also, keeping the weight as far from rotational center line as possible, serves to further increase the gain from the added rotating weight by effectively increasing the length of the lever that the weight is applying to the fulcrum.
Old 09-23-2012, 03:04 PM   #15
Cotten
El Diablo and Folks,
Please understand that I am not trying to re-invent flywheels;
I am trying to fix some S&Ss that are perfect in every way, except far too puny: "Dragracing flywheels" is exactly the opposite of what a sidehack needs.
Doncha all know that?
You do now.
I must add material of extreme density and mass.
Once again, I would be surprised to find any aluminum that even approaches the common malleable cast steel in stock wheels, or even brass.
"Leadalloy" used to be a recognized material that may be the best I can do.
Turning a section from a junk wheel is of course an option,
but it would at best only bring it up to stock or T&O specs.
Sidehacks enjoy flymass, and I want as much as I can possibly bolt on.
....Cotten
Late edit:
Fearnoevo!
The crank is blueprinted, balanced (60%), and trued already.
I only intend to drill and tap it for 1/4-20 countersunk bolts to hold on the additional mass.
I cannot see spending for anything that does not exceed the density of common materials
Cotten is offline
Old 09-23-2012, 03:05 PM   #16
old.wrench
old.wrench's Avatar
[email protected] try these guys cotton. All I'm saying is that I think we may have to wait a few more years before depleted uranium starts showing up in dumpsters
Old 09-23-2012, 03:13 PM   #17
FearNoEvo
FearNoEvo's Avatar
Cotten, what diameter and thickness are the flywheels? I can tell you exactly how much weight you could hope to add, if I can draw it up quick.
Old 09-23-2012, 03:21 PM   #18
old.wrench
old.wrench's Avatar
Tungsten is only slightly less dense than DU. If you can't get your hands on some DU, tungsten might serve your purpose.
Old 09-23-2012, 03:41 PM   #19
kickstarts
kickstarts's Avatar
Sounds like he has his heart set on Unobtainium and nothing else will do.
Old 09-23-2012, 03:44 PM   #20
Rubone
I think you should build an add on external flywheel along the lines of a bacon slicer Moto-Guzzi single myself!
Rubone is offline
Closed Thread
