Triumph cam gear and crank pinion gear puller tools - The Jockey Journal Board
Old 10-15-2011, 10:46 AM   #1
deluxe72
deluxe72's Avatar
Default Triumph cam gear and crank pinion gear puller tools
Hi. Do any of you in the Baltimore - D.C. area own these tools and if so would you be willing to let me come to you with my engine and allow me to pull these gears with your tools? These are the three gears inside in the timing cover that require a puller. It should only take a few minutes and I'll pay a nominal fee.
Please let me know.
Thanks.
deluxe72 is offline   Reply With Quote
Old 10-15-2011, 08:30 PM   #2
wildbill
Default Re: Triumph cam gear and crank pinion gear puller tools
You can take a number of the cheap pullers and grind the ends down to fit under the gears. it is a whole lot cheaper and works fine. Be careful and think about what you are doing.
wildbill is offline   Reply With Quote
Old 10-16-2011, 11:48 AM   #3
Frank D
Frank D's Avatar
I don't think that would work for atleast one gear--I think it's a lefthand thread that the tool threads onto to pull the gear off.
Frank D is offline   Reply With Quote
