Old STF VL neck cups - The Jockey Journal Board
Old 03-01-2016, 11:40 AM   #1
FredoTwoWheels
FredoTwoWheels's Avatar
Default Old STF VL neck cups
Anyone else running these? Can i just sit them right on the bearing race built into the neck stem or do i need to make a spacer for them to rest on? First build, lots of second guessing, thanks!
ID:	209217   Click image for larger version
Old 03-01-2016, 12:17 PM   #2
vtwinmotors
vtwinmotors's Avatar
Default Re: Old STF VL neck cups
Are you using ball bearings or going timken style.??
vtwinmotors is offline   Reply With Quote
Old 03-01-2016, 01:21 PM   #3
FredoTwoWheels
Default
They actually have sealed bearings installed in the cups
Old 03-01-2016, 01:31 PM   #4
jbfrmca
call mike at old stf. he'll get ya straight.
jbfrmca is offline   Reply With Quote
Old 03-01-2016, 01:51 PM   #5
VonWegener
VonWegener's Avatar
The old ball bearing race has to come off so that the new bearing seats properly.
The Timken bearing that fits the 1.125" VL stem and a standard Big Twin neck cup is part No. L44459 for anybody who is interested.
Name:	Timken L44459 VL to standard FL cup.jpg
Old 03-01-2016, 02:33 PM   #6
FredoTwoWheels
Default
So it should come off? Cause mine will not budge, were they pressdd on? Any tricks to removing them?
Old 03-01-2016, 03:05 PM   #7
VonWegener
VonWegener's Avatar
Yes they are pressed on which was standard Harley practice also on the Timken bearings. To remove use either heat or mechanical destruction like cutting with a dremel or grinder. Make sure not to nick the stem.
Old 03-01-2016, 04:15 PM   #8
PhilipRides
I have to vouch for Mike as well, he will definitely know what to do.
PhilipRides is offline   Reply With Quote
Old 03-01-2016, 04:35 PM   #9
FredoTwoWheels
Default
Right on, ill give it another go when i go out to the shop next. Thanks for always being helpful Mike. Thanks everyone!
Old 03-01-2016, 06:49 PM   #10
tomsoftail
tomsoftail's Avatar
If you hit them with a little weld won't they just fall out?
Old 03-02-2016, 11:57 AM   #11
ElekVins
I have an argument with someone about the VL stem.
I keep telling the guy OEM is 1"1/8 fixed stem and he keeps on telling me some VL front end had 1" removable stem from the factory, because he has one like this so he thinks it's oem...
Has anybody a document (part or service manual, harley history book...) stating the fact? Something that will look like official information because I'd like to close the argument with the guy and prove him he's wrong, but he's very stubborn...
(sorry Fredo for the hijack)
ElekVins is offline   Reply With Quote
Old 03-02-2016, 12:35 PM   #12
old.wrench
old.wrench's Avatar
Vins,
The guy selling that I-beam front end is totally wrong about the the 1" stem.
NO Harley I-beam front end had a 1" stem or a removable stem.
For verification, Palmer's book is about as reliable a source as you'll find. Tell him to check out page 94 in the second edition volume one under the heading "I-Beam Springer Forks".
Geo.
"it ain't rocket surgery"
"hony swacky mally asbestos"
Old 03-02-2016, 12:40 PM   #13
ElekVins
Yes Geo I know he's 200% wrong, but you know how it is when it turns to an argument...
Off course he wants to believe his front end is original, this way it has more value
I thought Palmer was only covering from 1936, do you have a way to scan that page 94 and post it here (or send me by email) ?
Or if you have no scanner, maybe a good pic will do the trick...
Thanks
Old 03-02-2016, 12:48 PM   #14
VonWegener
VonWegener's Avatar
Vins, the polish made for a dutch company VL frontends sold by W&W have a fixed 1" stem. They have been around for 20 years. Maybe one looks old enough to "be original" ?
The stem on those is also not the 1" springer type stem but resembles one of a timken bearing glide.
Old 03-02-2016, 12:51 PM   #15
ElekVins
I see what you mean, but the one this guy have has a removable 1" stem...
Making it even not original from W&W...
Old 03-02-2016, 01:00 PM   #16
VonWegener
VonWegener's Avatar
Maybe early model when they wanted to offer 1" and 1.125" stems? That would make sense. The Dutch guy was into restoration and found out later that there is a so much bigger market in the custom/chopper field.
Old 03-02-2016, 01:04 PM   #17
old.wrench
old.wrench's Avatar
Vins,
From the pictures I saw, that is definitely a VL I-beam springer, but the original stem was removed and replaced with that fabricated bolt on stem. He is right about the frontend, but wrong about the stem. The upper portion (above the yolk that joins the two legs) is much different on the European I-beams - more like a conventional tubular Harley springer than the Harley I-beams.
Geo.
Old 03-02-2016, 01:16 PM   #18
VonWegener
VonWegener's Avatar
Where the hell are the pictures? Is there something wrong again with my computer?
Not again...
Old 03-02-2016, 04:12 PM   #19
ElekVins
Not again...
Nothing wrong with your computer, I didn't post any pictures.
Geo saw them on PM....
Anyway, if someone can post up or send me the Palmer's book page 94 in the second edition volume one that would help me big time.
Thanks
Old 03-06-2016, 12:55 PM   #20
ElekVins
Bump...
Page 94 anyone?
