my plumbers beezer - The Jockey Journal Board
Old 02-23-2016, 12:17 PM   #1
lilbill
lilbill's Avatar
Default my plumbers beezer
did some labor trading with my plumber. part of the deal was resurrecting this old oif beezer. plans call for a new oil tank, clean the fuel system, fix an ignition problem, new tires/brakes, different exhaust, new wiring, replace the fork tubes and a general going over.
ID:	208009   Click image for larger version
RIP SwedeBobb
Old 02-23-2016, 03:06 PM   #2
Stinky Pete
Stinky Pete's Avatar
Default Re: my plumbers beezer
Maybe I'm not used to looking at British bikes, is that headlight mount common?
Railing against the darkness.
Old 02-23-2016, 03:09 PM   #3
richbob
richbob's Avatar
yes
Old 02-23-2016, 07:59 PM   #4
oldeiron
It is a stock headlight and mount for a 1971 or 72 oil frame BSA (or Triumph).
oldeiron is offline   Reply With Quote
Old 02-24-2016, 12:30 PM   #5
Ratso
Ratso's Avatar
This may be more of a statement about my failing eyesight than I'd like, but what are the two stacked, diagonally mounted cylinders behind the rear downtube?
Old 02-24-2016, 01:28 PM   #6
old.wrench
old.wrench's Avatar
Ratso,
That odd looking contraption is an oil tank. If you look closely you can see the oil lines and the filler bung. Sometimes, on the OIF brits, there may be a problem with the existing oil reservoir in the frame tube (leak or crud) and the owner adds an auxiliary tank instead of dealing with the problem.
Geo.
"it ain't rocket surgery"
"hony swacky mally asbestos"
Old 02-24-2016, 02:44 PM   #7
JAWS
JAWS's Avatar
Nice Bill.
Old 02-24-2016, 04:59 PM   #8
Ratso
Ratso's Avatar
Man after my own heart.
I've obtained two nearly free low-mileage Bonneville engines from people who blew holes in their OIFs trying to hardtail them. Glad it didn't occur to them to add an auxiliary tank.
Woops, sorry for the hijack.
Old 02-24-2016, 05:15 PM   #9
PhilipRides
Nice, great work!
PhilipRides is offline   Reply With Quote
Old 02-25-2016, 12:52 AM   #10
lilbill
lilbill's Avatar
yes, that's an owner built oil tank. basicly four 2" dia steel tubes 10" long welded together. i'll be replacing it with something more traditional. i was actually working for a tri-bsa dealer when the oif bikes came out. the bsa's had a problem with tank cracks at the rear motor mount from vibration. the factory would authorize warranty replacement of the frame. i remember they paid $65 labor for a frame swap.
RIP SwedeBobb
