What kind of gear oil do you use in your tranny - The Jockey Journal Board
Old 09-13-2015, 11:27 PM   #1
Oile
Oile's Avatar
Default What kind of gear oil do you use in your tranny
OK guys I was curious what you guys think is the best gear oil to use in my 50 fl?
Oile is offline   Reply With Quote
Old 09-13-2015, 11:36 PM   #2
Mule
Mule's Avatar
Default Re: What kind of gear oil do you use in your tranny
I use Lucas 80-90 high performance in all my shovelheads,
I got banned from Harley Tech Talk for asking a question!
Mule is offline   Reply With Quote
Old 09-14-2015, 06:14 AM   #3
govmule84
Forum Dipshit
Make sure you if you use gear lube, it's not GL-5, which is mostly what you find on the auto parts store's shelf these days. That shit tears up yellow metal, and you've got plenty of that in your FL's box.
Old 09-14-2015, 06:32 AM   #4
richbob
richbob's Avatar
Im using this GL4/GL5
I was unsure but seems like some manufactures have made it backward compatible.(read bit above recommendations in text below)
MOTYLGEAR75W-90Gearbox and differential lubricantTechnosynthese TYPE OF USESpecially recommended for gearboxes hard to shift and/or noisy gearboxes.All mechanical transmission, synchronised or not synchronised gearboxes, gearbox/differential, transfergearbox and hypod differentials without limited slip system operating under shocks, heavy loads andlow revolution speed or moderate loads and high revolution speed. PERFORMANCESSTANDARDS API GL4 and GL5 / MIL-L-2105DExtreme pressure lubricant for an efficient anti wear protection reinforced with synthetic base stocks fora better resistance at high temperature and longer life time.Stays in 90 grade after KRL 20 hours shear test as requested by SAE J306 Standard, July 1998 updateVery high lubricating power which decreases friction and wear.90 grade at hot temperature to provide outstanding oil film resistance at hot temperature and/or toreduce transmission noise.Fluid at low temperature to allow easier gear shifting when the gearbox is cold.Less effort required on the gear lever to shift the gears.Suitable for any type of seal and yellow material used in gearboxes design.Anti-corrosion, Anti-foam. RECOMMENDATIONS Oil change: According to manufacturers' requirements and adjust according to your own use. PROPERTIESViscosity grade SAE J306 75W-90Density at 15C (59F) ASTM D1298 0.868Viscosity at 40C (104F) ASTM D445 107.8 mm/sViscosity at 100C (212F) ASTM D445 16.7 mm/sViscosity index VIE ASTM D2270 171Flash point ASTM D92 200C / 392FPour point ASTM D97 -45C / -49F
Old 09-14-2015, 07:29 AM   #5
Just Passin' Thru...
As far as the best is a good question. I have a 50fl also and always used SAE60 motor oil in the hot weather, SAE50 in the cold...
Old 09-14-2015, 08:48 AM   #6
oilfield money
I;v been using Brad Penn 80-90 It is GL-4 . Made in the good old usa and fairly cheap
oilfield money is offline   Reply With Quote
Old 09-14-2015, 09:10 AM   #7
Truckedup
For bikes needing 90 weight....Brad Penn GL4 "classic" 90 weight. About 6 bucks a quart around here. If your tranny doesn't leak you may want to try Redline synthetic GL4 MT .
Old 09-14-2015, 10:28 AM   #8
Dave B
What Harley takes 90 weight ?. I just read the owners manual. 60 weight oil.
Dave B is offline   Reply With Quote
Old 09-14-2015, 10:30 AM   #9
geezer
geezer's Avatar
In an older bike like your FL I'd use Lucas 80W-90. If she's loose and noisy maybe a 85W-140.
Usually I'm a synthetic proponent but I've found the Lucas dino gear oils superior to synthetics. Especially in vintage iron.
Old 09-14-2015, 11:18 AM   #10
richbob
richbob's Avatar
dave b the gear oil thing equates the same
Old 09-16-2015, 08:21 AM   #11
sidehacker
sidehacker's Avatar
STP, straight STP.
sidehacker is offline   Reply With Quote
Old 09-16-2015, 12:44 PM   #12
JAWS
JAWS's Avatar
I use 60wt, same as the engine. I toss in Lucas stabilizer cause it keeps the stuff on the gears longer. I was sold when playing with the display toy in the parts house and figured it couldn't hurt.
https://www.youtube.com/watch?v=Qzirt1Vzmls I know it's not the same but it made sense in my head.
Old 09-16-2015, 02:19 PM   #13
Winston Wolf
Amsoil Severe Gear 75w-140 is all I use in my big twins nowadays. It makes gear changes much better; it is actually a noticeable difference.
Winston Wolf is offline   Reply With Quote
Old 09-16-2015, 02:50 PM   #14
wuzfuz
wuzfuz's Avatar
BelRay 75-140 in my Shovelhead for the past 25+ years, before that 20-50 Power Blend like the book said.
WUZFUZ
"Park my harley on a side street, wait for her in the dark, when she turn the alley struttin', every dog in the alley starts to bark"
wuzfuz is offline   Reply With Quote
Old 09-16-2015, 05:41 PM   #15
Nottso
Nottso's Avatar
Redline shockproof heavy.
Welcome to the Church Of The Holy Cabbage. Lettuce pray.
For small, extremely clean, remote oil filters please see my new Jock Shop.
Nottso is offline   Reply With Quote
Old 09-16-2015, 06:16 PM   #16
johnjzjz
johnjzjz's Avatar
bel ray 80/90 or bel ray 85/140
Old 09-16-2015, 06:53 PM   #17
Oile, getcha a panhead service manual if you can, nice bike!, congrats!
Old 09-18-2015, 08:01 PM   #18
76shuvlinoff
Another Redline Shockproof Heavy believer here. Nothing else in my 76 4 speed or the 5 inna 4 speed case for many years. Even dumped it in my TC.
76shuvlinoff is offline   Reply With Quote
Old 09-19-2015, 12:08 AM   #19
JAWS
JAWS's Avatar
Whats the deal with the shock proof or belray stuff? Benefits? Im up for learning.
Old 09-19-2015, 10:30 AM   #20
joe49
joe49's Avatar
After following the link that Jaws posted. I continued watching some of the videos that followed. This one is interesting.https://www.youtube.com/watch?v=A-bU6SByP0Y
