show & go factory PU drag build - The Jockey Journal Board
Old 07-02-2015, 01:09 PM   #1
fightclub
fightclub's Avatar
Default show & go factory PU drag build
Figured I would do my first build thread on the board. This one is going to take some time , but thought maybe starting thread would push me a bit more to keep it moving . Picked up an old non running pre unit hill climber . Factory rigid 53 frame , t120 engine, rigid tranny and primary, Lucas competition mag . Starting to collect the parts , direction will be a 60"s show style drag bike . Just got the rubber delivered , M&H drag slick, 2.75 x21 firestone front tire. 1929 Harley Davidson Springer pea shooter . I'm going to have a lot of ? for the pre unit guru's since this is my first one , only familiar with the unit stuff .
fightclub is offline   Reply With Quote
Old 07-02-2015, 01:19 PM   #2
oilfield money
Default Re: show & go factory PU drag build
Holy crap . Now I'm excited . It already looks killer
oilfield money is offline   Reply With Quote
Old 07-02-2015, 02:59 PM   #3
stuckzilla
stuckzilla's Avatar
I'm smellin what you're cookin. Peashooter looks tits. Keep it coming.
stuckzilla is offline   Reply With Quote
Old 07-02-2015, 03:08 PM   #4
drumrooster
drumrooster's Avatar
Excellent keep us posted
"NO PICTURE. NEVER HAPPENED..."
drumrooster is offline   Reply With Quote
Old 07-02-2015, 04:55 PM   #5
SxExCx
nice stance
SxExCx is offline   Reply With Quote
Old 07-02-2015, 06:52 PM   #6
panhead_pete
Got any pics of it before you tore it apart?
Thanks
Pete
Old 07-02-2015, 08:23 PM   #7
fightclub
fightclub's Avatar
Thanks for the feedback guys
panheadpete, this is how she sat .I tour into the engine ,holy cow . 100 over piston, and some really crazy crank machining .will post some pics later
Old 07-02-2015, 08:52 PM   #8
KCgran
Okay, I will be the first to admit I'm dense when it comes to triumphs, but .100 over is almost an sixteenth inch out of the cyl. Walls. Was it factory jugs? Did they re-line the jugs with an over sized liner?
Old 07-02-2015, 09:14 PM   #9
fightclub
fightclub's Avatar
I will take some picture, its as you said KCgan , cylinder walls were about 1/16 from the head bolt wholes. There was some crazy stuff going on. The head was professionally speed wholed lightend , and wait till I post the crank pics . It was used exclusively to hill climb ,check out the oil tank
Old 07-02-2015, 10:05 PM   #10
Zeeman
Zeeman's Avatar
Lookin' good. Planning to rake the frame at all? How about motor mods?
Wanted: Cal Products C8 transmission case
https://www.jockeyjournal.com/forum/...58#post2063958
Zeeman is offline   Reply With Quote
Old 07-03-2015, 08:34 AM   #11
fightclub
fightclub's Avatar
Zeeman, I'm going to leave frame stock ,I'm a short guy so I shouldn't look to jammed up on it. I'm not building it as a race bike to drag, in fact I'm on the fence with the rear tire or going with stock 19 rear . You know form over function. I will see how build progresses. Same for engine ,I'm going to re build it but nothing crazy. I think you guys will find below pictures entertaining to say the least
Old 07-03-2015, 09:31 AM   #12
Mike Britton
Mike Britton's Avatar
Wow! Those are some big jugs! Insert a Terrie Garr sexist comment here.
I don't understand the drilling the head thing. Does it actually add enough surface area to help cooling, or is it mostly for looks.
Old 07-03-2015, 09:31 PM   #13
vorhese
vorhese's Avatar
wow... crazy stuff
gonna be a cool one
Old 07-04-2015, 09:39 AM   #14
UGOTBIT
UGOTBIT's Avatar
Old school "speed" is bad ass. The engine is wild!
1967 TR6 = 650 ways to waste money.
UGOTBIT is offline   Reply With Quote
Old 07-04-2015, 12:29 PM   #15
JAWS
JAWS's Avatar
Someone spent a lot of time...
Old 07-04-2015, 01:41 PM   #16
old.wrench
old.wrench's Avatar
The little Harley springer is a perfect match for that bike, the scale and proportion looks right on.
The motor looks to have been built for quick revs, the burst of power that you need for hill-climbing.
What was the old oil tank made out of? A propane bottle?
Geo.
"it ain't rocket surgery"
"hony swacky mally asbestos"
Old 07-05-2015, 08:08 PM   #17
fightclub
fightclub's Avatar
Hard to say old wrench but it only holds enough oil for short runs
Old 07-06-2015, 03:31 AM   #18
richbob
richbob's Avatar
Good Stuff
your going to rebuild it "but nothing crazy" does that mean you won't or can't(worn out) use existing speed/modified parts?
Old 07-06-2015, 09:37 AM   #19
Mike Britton
^^^^^Dummy question here, how well would that lightened bottom assembly stand up to street use?
Old 07-06-2015, 08:48 PM   #20
fightclub
fightclub's Avatar
Originally Posted by richbob View Post
Good Stuff
I'm going to try to use as many of the modified parts in current engine as I can, if they can be used to give me a reliable engine. I'm not going to run 100 over pistons so they are scrap .If I can use the crank ,I will have it balanced I will .I will have all my machining done by Dan at Fag engine , new top end as well. I realize using an engine that was built for hill climbing is not an optimal platform to start from for zipping around town.
