Another sparkplug quiz - The Jockey Journal Board
Old 06-13-2015, 01:19 PM   #1
oilfield money
Default Another sparkplug quiz
I have a new freshly built 58 6T with the iron head . I;m getting all the bugs worked out but the plugs are showing half good and the other half a little rich and when I say half , I mean like perfectly down the center . no matter how the plug goes in , The line is perfectly down the center of the terminal arm . The bike runs great but just a little curious whats going on ?
oilfield money is offline   Reply With Quote
Old 06-13-2015, 02:16 PM   #2
little d
little d's Avatar
Default Re: Another sparkplug quiz
Oil,
in a perfect world a combustion chamber would have a very even/uniform burn, this is rarely the case. Several things can affect this, combustion chamber shape, high dome pistons, sparkplug to valve location, the carb's ability to atomize the fuel, the fuel itself and even the port shape and direction comes into play here.
There is a video somewhere where they use a clear cylinder/head and slomo to film it, it shows what happens when ignition happens and shows the burn.
Just shooting from the hip here so take this for what it cost ya but, i would think what your seeing is the plug is not in a good position, only part of it is in a good burn and the rest of it is in a leaner area.
Are you using the right plugs? A shorter plug may pull the ignition point away from the good mix.
Are you running the right fuel to compression? Running a lower grade of gas with higher compression will let the gas burn before it fills the combustion chamber (this causes what is known as "ping" causing the piston to hit the cylinder wall.
Old 06-13-2015, 02:32 PM   #3
Rob Axel
Rob Axel's Avatar
Little D....please post that video if you find it...and your answer also helped me with my plug 'fouling' issue..I think Im getting oil into the chambers from old valve guilds...
I have also learned, each state has mandates on their fuels....The best gas here in Ga. is crap compared to the worst gas in South Carolina...
"The heart is happiest
Old 06-13-2015, 03:00 PM   #4
oilfield money
Thanks little D , I;m using the correct plug the preunit iron head calls for a 1/2 reach and I'm running a tad bit warmer plug which is the NKG 6 just because the old thunderbirds are fairly low compression and ad least in my mind I think it runs better . What to me is odd is that the overly rich line is perfectly down the center and the other half is that nice tan color
Old 06-13-2015, 04:07 PM   #5
richbob
richbob's Avatar
I'm running a 5
round town
6 was fouling but on a 3 hour motorway thrash(70mph +) no fouling but still looked rich.(I'm twin carbs 26mm Kehihn)
Old 06-13-2015, 04:23 PM   #6
Elffors
Elffors's Avatar
This thread is useless without pics
I support Rolling death Hawai!
IG @the_elffors
Old 06-13-2015, 06:04 PM   #7
VonWegener
VonWegener's Avatar
And just to throw more fun into the mix. There are counterfeit NGK plugs being sold that are supposed to have problems. And I had Problems with brand new champions where on a V8 one new plug was just bad. Got a new one and it was bad also. That was the end with Champions for me.
Old 06-13-2015, 09:13 PM   #8
JAWS
JAWS's Avatar
Did you index your plugs? With the plug centered between both valves and the strap centered, the intake side will be cleaner. Fuel is a solvent.
Old 06-13-2015, 10:41 PM   #9
oilfield money
I never indexed them I just randomly run them down tight . But what would be the chances that they landed that way with the center strap centered up between the intake and exhaust valve ? But I will change the plugs and mark them to see how they land when they bottom out . I agree a pic would really help but that's another unknown I need to learn how to do
Old 06-15-2015, 06:30 AM   #10
little d
little d's Avatar
Rob,
I looked last night for it but couldn't find it, sorry, wish I was better at this internet thing but, Ill keep looking. Anyway, it showed what I described, the fuel/air mixture filling one side of the chamber, being compressed and firing off. With the slomo, you could actually see the piston moving and hitting the side of the cylinder, it was a Aw Ha moment for me.
Von,
I had the same issue with my Wife's 340 Mag, 1 weak cylinder I chased for what felt like forever, swapped out the plug and bingo. Lesion learned.
Jaws is right, fuel makes a hell of a cleaner. When I'm dialing in a motor, I pull the clutch in and kill it instead of letting it coast down to minimize the washing down.
Old 06-15-2015, 11:27 AM   #11
Rob Axel
Rob Axel's Avatar
Von....funny you say "bad new plugs".... I've got a thread somewhere on here where my wife "fixed" my bike...by asking "can new spark plugs be bad" when I was chasing a gremlin in my motor...
