Cleaning for a Show - The Jockey Journal Board
Old 05-04-2015, 01:28 PM   #1
robert s.
robert s.'s Avatar
Default Cleaning for a Show
Entering my 650 in a show in a couple of weeks. It's pretty grimy and dirty on the underside, with some caking too in inner mudguards.
Aside from brushes, rags, Simple Green and elbow grease, any recommended products out there that clean well, yet are easy on paint and aluminum?
1968 Triumph Bonneville T120R
1969 BSA Victor 441 Special B44VS
1970 Triumph Trophy 500 T100C
robert s. is offline   Reply With Quote
Old 05-04-2015, 01:58 PM   #2
little d
little d's Avatar
Default Re: Cleaning for a Show
Robert,
I've had real good luck with a product called pig snot.
Old 05-04-2015, 02:55 PM   #3
wuzfuz
wuzfuz's Avatar
Dow foaming bathroom cleaner works well. Just like s-2000 but much cheaper. If you have a Dollar General store their house brand is good. Prep-sol on a rag will dissolve a lot of grime under the bike but if you can put it on a jack and gunk it then pressure wash would be better.
I like to detail bikes and cars as it gives me a reason to sit back, drink a beer, light one up and admire my work.
wuzfuz
"Park my harley on a side street, wait for her in the dark, when she turn the alley struttin', every dog in the alley starts to bark"
wuzfuz is offline   Reply With Quote
Old 05-04-2015, 02:57 PM   #4
Mr Bill
Mr Bill's Avatar
After you've washed & dried the bike, spray and wipe paint, chrome, glass and plastic with Liquid Ice detailing spray. You'll be pleasantly surprised with how easy it removes streaks and polishes out.
No matter how low you sink there's still a right and a wrong, and you always end up choosing.
You go one way so you can try to live with yourself.
You can go the other and still be walking around, but you're dead and you don't know it.
Mr Bill is offline   Reply With Quote
Old 05-04-2015, 03:44 PM   #5
robert s.
robert s.'s Avatar
Originally Posted by wuzfuz View Post
... if you can put it on a jack and gunk it then pressure wash would be better.
All good advice and agree, a detailed bike can be very satisfying!
Gunk is OK on raw cast aluminum cases and paint?
Old 05-04-2015, 05:59 PM   #6
old.wrench
old.wrench's Avatar
Robert,
I've used it for years and never yet had a problem with Gunk damaging cast aluminum or paint.
I just tried another Gunk product, it's supposed to be a spray-on detailer for motors. You just spray it on after you've already got every thing cleaned up. I was looking for something to apply to a new set of heads to hopefully make future cleaning a bit easier. It's a real pain trying to clean in between those fins. The jury is still out as far as how it holds up over time, but it puts a nice soft glow on cast aluminum. Or . . maybe I just bought 5 bucks worth of horse-piss .
I would be careful about using a pressure washer though. I did some work on a bike that the owner pressure washed and months later I found water in places that you don't ever want to see it - like inside the transmission case. About all I could figure is that somehow it found it's way in through the vent, a couple of tablespoons full. The motor oil showed evidence of water contamination as well, sort of milky looking .
Geo.
"it ain't rocket surgery"
"hony swacky mally asbestos"
Old 05-05-2015, 04:50 AM   #7
wuzfuz
wuzfuz's Avatar
About pressure washing I agree you can go over board. I spray from a distance to get the effect of the high water flow but use some moderation. Always stay away from wheel bearings and wire junctions. On the bottom of the bike should be no problem.
WUZFUZ
Old 05-05-2015, 10:51 AM   #8
hogster
hogster's Avatar
Location: find the nicest trailer in the park,I live under it
dont forget to put on clean underwear and ,get behind the ears
looking for a good re-tox facility
hogster is offline   Reply With Quote
Old 05-05-2015, 11:06 AM   #9
JAWS
JAWS's Avatar
Do NOT use Castrol Super Clean...that purple shit will clean everything off and make your polished surfaces gray and dull.
Old 05-05-2015, 12:45 PM   #10
Ember
Gibbs lube for me. Cleans, water proofs and keeps things from rusting. Also great at removing chain lube.
Ember is offline   Reply With Quote
Old 05-05-2015, 01:21 PM   #11
oilfield money
I think I heard this from someone her on JJ ,But they had said when cleaning your bike , " soap and water are for your genitals not your bike " Words to live by I guess
oilfield money is offline   Reply With Quote
Old 05-05-2015, 01:35 PM   #12
magnum45pete
magnum45pete's Avatar
if ya keep it clean as much as you can, you wont need much cleaning when it comes to a show.....plus the bike will look better all the time,
less ''Rot'' will set in and the bike will never have that old ,tired ''Rebuild Me'' look....... I'm NOT the best at keeping a bike imaculate, but do try to keep it presentable as much as I can..
also a benefit is when cleaning weekly or even monthly you will find any loose nuts n bolts,fractured brackets,broken parts,Nails in ya Tyres, freyed cables and adjusters that need adjusting...so ya get a safer bike as well !!
