Angry Monkey Motorcycles '58 Triumph Build "Old Man" - The Jockey Journal Board
Old 08-20-2014, 02:09 PM   #1
supercrouton
supercrouton's Avatar
Default Angry Monkey Motorcycles '58 Triumph Build "Old Man"
Well, I was holding out to do a build thread on my next personal bike to show off a few cool details we have been developing, but that keeps getting pushed back with client work. For those of you that know the "formulaic" look of our bikes, this one should be the best of the best, for whatever that is worth:
Chopped, narrowed, flat-bottomed, split 3.5g HD tanks (big filler caps)
16", 21" wheels
SHORT rigid rear section
Euro-made HD replica springer front end
Paint by Ryzart
So, here we go again..... This time the subject is a seized '58, with a titeld, numbers-matching frame and motor.
Since the motor was seized, I thought it would be a good idea to go ahead and get that at least split and assessed before proceeding too far.
With the help of a hole-saw the pistons gave up their positions in the cylinders.
Old 08-20-2014, 02:30 PM   #2
supercrouton
Default Re: Angry Monkey Motorcycles '58 Triumph Build "Old Man"
Dan at FAG Engine got the crank and rods sorted. While I was waiting, I took care of a what I could without the crank and rods.
rocker spindles cleaned and polished...
Bead blast, and rebuilt rocker boxes...
Bead-blast cases.
Since the client wants no battery, this will be an alternator bike. Here is a block off for the generator hole that I made out of 1/4" alloy.
Fresh from Dan at FAG Engine: bored/honed/painted cylinders, re-bushed and weight-matched rods, and new pistons with fitted rings...
Old 08-20-2014, 02:42 PM   #3
supercrouton
Since this bike will have a dry BNR belt drive, an oil seal had to be retro fitted to the drive-side case...
Alignment tool setting the ring...
Ready for a proper oil seal...
Head cleaned and bead blasted...
...Typical head bolt boss cracks
grind, TIG, grind, file...
Deck the head
Old 08-20-2014, 02:46 PM   #4
supercrouton
New brass guides, installed and bored...
new stainless valves lapped in place
new springs and hardware
The head is ready...
Old 08-20-2014, 03:03 PM   #5
boondocker
Awesome as usual...
boondocker is offline   Reply With Quote
Old 08-20-2014, 03:13 PM   #6
supercrouton
Originally Posted by boondocker View Post
Awesome as usual...
Thanks!
Oh, and I added a proper oil seal for the crank feed: I TID'd on extra material around the feed boss, then turned out the recess to fit a "unit" seal and clip.
More to come...
Old 08-20-2014, 04:27 PM   #7
vorhese
vorhese's Avatar
nice work danielson. I have some JB Weld I can share if you want some.
Old 08-20-2014, 04:32 PM   #8
supercrouton
Heck yeah! Send it! These ring things are the only place I use the stuff.
Old 08-20-2014, 06:27 PM   #9
fightclub
fightclub's Avatar
Keep em coming Dan. I Can't say nothing but great things about the other Dan from FAG Engine as well, just a stand up dude
fightclub is offline   Reply With Quote
Old 08-20-2014, 08:22 PM   #10
rooster
rooster's Avatar
Interestingly awaiting more awesomeness...
SHOVELHEAD- if it ain't broke it will be.
rooster is offline   Reply With Quote
Old 08-20-2014, 08:37 PM   #11
Rob Axel
Rob Axel's Avatar
With my first pre unit build nearby.... I am taking lots of notes!...
"The heart is happiest
Old 08-21-2014, 03:15 AM   #12
Daddy Boy
Music to my eyes Dan.
Old 08-22-2014, 11:25 AM   #13
Rob Axel
Rob Axel's Avatar
Thought about going with the Alton gen/alt... Going to look into doing the crank alt also since I have a few hanging on the wall and more about reliability rather than "original"..
Old 08-22-2014, 08:04 PM   #14
hooks2u
hooks2u's Avatar
nice brother I've been wanting to call you here sometime soon to say hi and pick your brain about some performance mods on my motor
hooks2u is offline   Reply With Quote
Old 08-22-2014, 09:15 PM   #15
Robik
Robik's Avatar
Dan, all your builds inspire me a lot! Looking for the donor bike now...
Thanks for the great share.
Robik is offline   Reply With Quote
Old 08-23-2014, 04:29 AM   #16
richbob
richbob's Avatar
Good start, Nice
I have a question I'm running BNB Racing drive and have a similar oil seal set up to you.
I've done a couple of thousand miles on bike and now I'm wondering about breathing
did the engine breathe through here into primary?
because when i stop(After a thrash) i have maybe 2 teaspoons of oil under bike at crankcase breather(for sure some oil is misting out when running.
Also do you do anything at gearbox mainshaft bushing? (I'm using longer bronze bush)I have a weep there that flicks onto back of clutch basket i was thinking of putting an oil seal there.
thanks
richbob is online now   Reply With Quote
Old 08-23-2014, 01:02 PM   #17
supercrouton
Thanks for the support guys! I will try to be as thorough as possible with the pics and whatnot.
Call anytime Chuck, I'm glad to help.
Old 08-23-2014, 01:12 PM   #18
supercrouton
Originally Posted by richbob View Post
Good start, Nice
thanks
There was a little breath-through to the primary, but not much. Remember that the next model up came with a seal on the drive-side case and they both have the exact same cam-driven, crank breather, window arrangement. BTW, Often overlooked is the seal quality of the timing-side case half to the generator. If it is not sound, more oil will get spat out of the crank breather tube, as well as other areas.
Cheers, Dan.
Old 08-23-2014, 01:32 PM   #19
supercrouton
more updates. This beast was in desperate need of some love.
New Brushes, bearings, seals, condensor, and a thorough cleaning/bead-blasting on my end. Then I sent the mag out to be re-magnetized and hot-run checked, The original armature, pick ups, and slip ring tested perfect, as did the new Bright-Spark condensor. Check one of my tech threads about these IC capacitor. It is the single best thing ever made new for these K2FC mags. I have put several K2FC's back into service with these caps and just a basic cleaning and tuning.
Next is the box...
Old 08-23-2014, 09:25 PM   #20
supercrouton
this bike gets the pimp Euro-made HD repop front end. So, if you're thinking about one for a triumph, here's how it works...
first remove this ring from the bottom of the stem.
Chuck up the castle nut...
Face it off to the right length. Also notice the shoulder cut on the right side...
open up the hole on a dust cover, or make one from scratch.
I like them to fit nice and flush...
...A little silicon bronze to keep from over heating the thinner dust cover.
Get the right Timken bearings and adapters for the Triumph neck cups and BAM! Like a glove. but what about those unsightly threaded holes in the rear legs?
Turn up a pair of reducing bungs...
That fit in there like this...
Then turn a couple tapered, counter-bored alloy bungs, and top them with some ss socket head bolts.
Here are a couple cold-rolled axles I made for this bike and the next. Castle nuts locked down with cotter pins will give some piece of mind out on the road.
Tags
angry monkey, pre unit, supercrouton, triumph
