magneto condenser / ease of starting discussion - The Jockey Journal Board
Old 08-13-2014, 10:35 PM   #1
dhallilama
dhallilama's Avatar
Default magneto condenser / ease of starting discussion
chevelle brought up something interesting regarding the magneto primer/sticky that has me questioning what i've always known (thought?) regarding mags and low RPM (starting) operation...
here's what i've always thought: the higher mfd (within reason) the easier the mag fires at low RPM. really thinking about this, it doesn't necessarily make sense. lower capacity (mfd) might have a higher voltage at low RPM, yes? if so, that kinda turns what i've been going off of upside down.
care to discuss?
the common condensers i know of are:
Morris P6 ( ~.20mfd)
FM AXMR2433 (~.22mfd)
NAPA SME 701308 ( ~.22mfd)
Accell's "high performance" ( ~.26mfd)
FM SXY2433 ( ~.32mfd i think)
NAPA FM 200 (same as above)
FM RX2433 (.48mfd... never ran one)
dhallilama is offline   Reply With Quote
Old 08-13-2014, 11:53 PM   #2
LivingCanvas
LivingCanvas's Avatar
Default Re: magneto condenser / ease of starting discussion
Hey I had just came to the same conclusion! I do a lot of reading and searching on this site trying to gather as much info as possible. I also thought higher is better. Then I read the same info in the stickies...
Inquiring minds want to know
LivingCanvas is offline   Reply With Quote
Old 08-13-2014, 11:59 PM   #3
BobAsh
BobAsh's Avatar
Not higher voltage, that will be constant The higher capacity cans should deliver more current, but the cycle time would be slightly longer.
BobAsh is offline   Reply With Quote
Old 08-14-2014, 12:09 AM   #4
dhallilama
dhallilama's Avatar
i swore there was something about it in How to Build a Harley-Davidson Torque Monster by Bill Rook... but i can't find my copy & google books is missing page 61(ish)
so, if the lower mfd condenser = a higher low rpm current, it would (i assume) also = easier starting? with the drawback being high rpm issues...
i may have been dead sure about my previous assumptions (which is where the sticky info came from). always willing to learn...
Old 08-14-2014, 04:26 AM   #5
C1340
A higher capacitance can store more energy in the capacitor and will deliver a hotter spark / higher voltage compared to a lower capacitance at the same RPM.
Energy in a capacitor is E=1/2 x C x V^2 with C the capacitance and V the voltage, which is related to the RPM. In practice when the points open and the voltage in the coil is transferred to the secondary side, the capacitor "slings" the voltage up to an even higher amplitude. The more capacitance, thus the more energy stored, the higher the voltage gets "slung up"
It is most handy for magneto's with kick start only. The downside is, you'll burn your points faster. Nowadays Morris M5 capacitors standard is 18uF and the higher capacitance is 26uF.
C1340 is offline   Reply With Quote
Old 08-14-2014, 08:46 AM   #6
BigDawg
Send a message via AIM to BigDawg
I had Hank at Morris give me their (I wanna say) "S" condenser a couple of years ago. It's considerably larger than the "P" or "R", but I'm unsure of the capacitance, but I know that it starts a bit easier than with the "P" that was on it originally. It was at his suggestion that I try it out and I was pleasantly surprised.
Sometimes you just want to turn dinosaurs into noise.
The BDAC
BigDawg is offline   Reply With Quote
Old 08-14-2014, 08:47 AM   #7
revkev6
hmm. interesting discussion. I don't really know about points and magnetos but I have read some ignition threads over on the jalopy journal. there is an ignition guy over there who posts up some information, tutorials and such. GMCbubba is his SN. He posted up that if you have the wrong condenser in a regular distributor it will severely effect point life. basically he said that by checking which side of the points are burnt will tell you if you have too much or too little capacitance in your condenser. He never really mentioned it having an effect on power or starting.
revkev6 is offline   Reply With Quote
Old 08-14-2014, 10:54 AM   #8
66headysporty
This is awesome thanks for starting this, I haven't done all that research etc. I just was amazed at the difference it made when I switched my old one which I don't know what it was no marking to a fm200.
66headysporty is offline   Reply With Quote
Old 08-14-2014, 11:26 AM   #9
Dave B
Throw the Accel ones right in the garbage. If it is not a F-M condensor you are annoying yourself for no reason.
Dave B is offline   Reply With Quote
Old 08-14-2014, 12:55 PM   #10
old.wrench
old.wrench's Avatar
dhalli,
I'm not sure how it relates to kick-starting vintage bikes, but the mofos at the Moco determined that condensers with a higher micro-farad rating (like .30 m.f.) gave better performance (especially points life) at lower rpm's and speeds, and condensers with a lower m.f. rating (like .18 m.f.) functioned better at higher sustained speeds. This info relates primarily to the police bikes the factory supplied. Think "meter maid" machines for low speed, and State Highway Patrol for high speed. The "middle-of-the-road" condenser for regular use was .23 m.f.. There is some further information in Palmers book.
Geo.
"it ain't rocket surgery"
"hony swacky mally asbestos"
Old 08-14-2014, 01:27 PM   #11
dhallilama
dhallilama's Avatar
the only two times in my life a condenser went out on me, leading to changing it on the side of the road, they were Accel. (neither on Harleys)
the only two times coils shit the bed; Accel.
I don't buy anything from them anymore.
Old 08-14-2014, 10:01 PM   #12
chevelle
Here is a bit of info regarding the FM magneto condensers for XLCH's.
Pretty much sums up what I've found researching condensers for mags.
http://xlforum.net/vbportal/forums/s...1&postcount=50
chevelle is offline   Reply With Quote
Old 08-15-2014, 01:26 AM   #13
dhallilama
dhallilama's Avatar
well... Dr Dick does seem to know his shit (read a ton of his posts over the years)...
though it contradicts what i've heard over the years (more or less what C1340 stated, above).
all interesting stuff...
