Powder Coating over Chrome - The Jockey Journal Board
Old 07-23-2014, 01:09 AM   #1
hd74
hd74's Avatar
Default Powder Coating over Chrome
Anyone have any success powder coating over fresh chrome plate?
My Chopped Pan https://www.jockeyjournal.com/forum/s...d.php?t=131586
hd74 is offline   Reply With Quote
Old 07-23-2014, 06:34 AM   #2
Dr. Benway
Mod Squad
Dr. Benway's Avatar
Default Re: Powder Coating over Chrome
I had some chrome forwards done a long time ago; the powder stuck with no problems.
Old 07-23-2014, 10:47 AM   #3
BobAsh
BobAsh's Avatar
Yeah, no worries if the chrome is good. The only real problem is if the chrome peels.
BobAsh is offline   Reply With Quote
Old 07-23-2014, 11:21 AM   #4
Mr Bill
Mr Bill's Avatar
Bead blast the chrome first, being careful not to peel any off. Clean up with acetone & virgin paper towel while wearing nitrile gloves, position part in its cooking position while still wearing the gloves, preheat for 30 minutes @ 450*, coat, bake to an even runout (~5 min) @ 450*, cure for 20 min @ 400, don't touch the powder until it cools down or you risk smearing the finish.
This is for standard powder; there's a different procedure for hi-temp coatings.
No matter how low you sink there's still a right and a wrong, and you always end up choosing.
You go one way so you can try to live with yourself.
You can go the other and still be walking around, but you're dead and you don't know it.
Mr Bill is offline   Reply With Quote
Old 07-24-2014, 12:18 PM   #5
hd74
hd74's Avatar
Sounds solid, heading to a local coater to see what they use to mask there parts.
Old 07-24-2014, 02:09 PM   #6
BobAsh
BobAsh's Avatar
They sell the masking tape for this purpose on ebay.
Old 07-24-2014, 02:45 PM   #7
Mr Bill
Mr Bill's Avatar
I use two different hi-temp masking tapes; one looks like fiberglass tape with the linear strands, I use this as general purpose. The other, more expensive tape is hi-temp silicone based, this gets used where trimming with the exacto knife is required: it cuts clean where the 'glass tape frays.
Both styles come in several widths but I only buy the skinny stuff. If I need to mask a large area I use aluminum foil and tape down the edges.
edit: before and after shots of the chrome oil tank, battery box and clutch arm
Old 07-24-2014, 08:08 PM   #8
BobAsh
BobAsh's Avatar
I haven't seen the reinforced kind; I'm using the green plastic stuff. Seems to work fine.
Also I use those tapered silicone plugs for keeping holes clean. Here's my setup:
Old 07-24-2014, 10:50 PM   #9
Mr Bill
Mr Bill's Avatar
mmmmm...... Modified double wall oven... Very Deluxe. I'm still using a single Harvest Yellow Admiral range with a side of toaster oven.
Old 07-25-2014, 09:46 AM   #10
bustedlifter
Haha! My operation is the same, except I'm waiting on getting the 220 outlet installed in my garage.
Old 07-25-2014, 12:53 PM   #11
hd74
hd74's Avatar
Here are the two parts to be PC. What I've done here is masked off the areas with Gorilla tape. Any suggestion on what PSI for the blast?
Old 07-25-2014, 11:38 PM   #12
Mr Bill
Mr Bill's Avatar
Wow... those are hard on the eyes (so are the reflections...)...
You want to just dull the surface when blasting, to give the powder something to grab on to. I run my blaster at 60# with #6 glass bead for everything (it's pretty much used only to prep for powder).
Old 07-28-2014, 05:21 AM   #13
CRAZYBEN
Gosh them sure are some pretty bits!
CRAZYBEN is offline   Reply With Quote
Old 08-02-2014, 12:52 PM   #14
Danny F.
Danny F.'s Avatar
The black oil tank used on a stock FLSTS (Heritage Springer) is factory powdercoating with brand new chrome underneath... I've seen in two occasions that the coating on the oil tank could be pulled off as a plastic cover... That's why I know the chrome under there was brand shiny new..
I also noticed that the black risers on a Softail Springer Night-train is factory black powdercoating over brand new chrome..
So I guess they used more coated black parts on some models with new chrome underneath..
Just saying..
It's a thin line between just right and overdoing it...
Danny F. is offline   Reply With Quote
Old 08-03-2014, 05:46 PM   #15
hd74
hd74's Avatar
Thanks for all the info guys and so this is what I did with it so far. After masking I bead blasted both fender and tank, if you look closely at the pix you can see some frosting. Even with the reduced air pressure their was still some bobbling of the plating. The good news it was all in non critical areas. After getting them home I washed them and put them in the oven
@450 for 20 min. just to be sure they will make it through the powder coating process. I will re-mask the areas I want to keep shinny and hopefully I will get them coated tomorrow.
Anyone see any problem in sanding away problem areas?
Old 08-03-2014, 07:57 PM   #16
Mr Bill
Mr Bill's Avatar
Define "sanding away problem areas"... Not sure what you mean...
Although I can see the pitting in the chrome they're still too shiny for my liking; if you're not comfortable putting them back in the blast cabinet, consider scratching up the surface with 80 or 100 grit paper. Use fresh paper and don't be shy about changing it out when it loses its sharpness.
Old 08-05-2014, 08:46 AM   #17
hd74
hd74's Avatar
Although I can see the pitting in the chrome they're still too shiny for my liking; if you're not comfortable putting them back in the blast cabinet, consider scratching up the surface with 80 or 100 grit paper. Use fresh paper and don't be shy about changing it out when it loses its sharpness.[/QUOTE]
I considered both methods but felt the texture of the bast will do the job. Dropped the fender and tank off yesterday at our local coater, hopefully I will see them back later today.
Old 08-07-2014, 09:07 PM   #18
hd74
hd74's Avatar
Powder applied, next step is paint.
Old 08-07-2014, 09:46 PM   #19
Mr Bill
Mr Bill's Avatar
Sweet. Going to pinstripe?
Old 08-08-2014, 09:13 AM   #20
hd74
hd74's Avatar
The powder was just to give the paint something to hold on to...
