4 speed leak.. again - Page 2 - The Jockey Journal Board
Old 06-28-2019, 10:47 AM   #21
Default Re: 4 speed leak.. again
Yep . . . and clean up any burrs/gouges in the trans case when replacing the main seal. Use some sealant where the seal meets the case. Make sure it goes in square.
Old 06-28-2019, 05:16 PM   #22
^^^ the square part...... in a round hole.
Old 06-28-2019, 06:51 PM   #23
Oh, how's this:
Ensure that the transmission case main drive gear oil seal is installed coaxial with the main shaft boss on the transmission case, that the boss is free from surface abnormalities and flaws which could provide a path for lubricant to escape, and that an appropriate duty sealant is employed.
Old 06-28-2019, 09:42 PM   #24
Way more gooder and smarter.
