41mm Wideglide Axle spacer dims - The Jockey Journal Board
Old 06-22-2019, 11:18 AM   #1
Default 41mm Wideglide Axle spacer dims
Hey all.
Currently in the process of putting a 10" over wideglide on my UL. I've got the axle but no spacers, Could anybody kindly give me some measurements so I can machine some?
cheers!
Old 06-23-2019, 07:48 PM   #2
M.O.Ther
M.O.Ther's Avatar
Default Re: 41mm Wideglide Axle spacer dims
Not enough information. It would help to know what year forks, or at least the range. Drum or disc forks? American made or Showa? what kind of a wheel are you running? Are you using a brake, and if so, what kind?
In theory there is no difference between theory and practice. In practice there is. Yogi Berra
M.O.Ther is offline   Reply With Quote
Old 06-24-2019, 06:53 AM   #3
Hi Sir,
I'm not very well versed with the hydra forks, it's a 41mm, with the legs shaved. I've got early pan trees with the deraked neck.
I don't believe they're showa, the collars on the fork tubes are on outside? I believe they changed later on? I can't really offer anymore than that.
I have looked online but I can't find any sizes.
Old 06-24-2019, 11:11 AM   #4
dbkp
Are there vent holes on the sides of the top tube caps(one each on the sides of them)? If so they are pre 77 U.S. made
" And there was Old Sneep, sucking on a lemon"
Old 06-24-2019, 11:30 AM   #5
Math and measurements. Forks and sliders in trees no springs, collapse fork measure inside at axle holes in sliders, subtract width of wheel hub = total of space on both sides of wheel. Next measure offset of rim center line from both sides. Divide inside measurement of forks in half, then subtract rim offset for spacer length. Do both sides. Results of both spacers should add up to total of space on both sides of wheel.
Old 06-24-2019, 02:32 PM   #6
That's basically what I did given the mix of sliders, hubs, discs and calipers I have. Did the same with the rear. Seems to track fine.
Old 06-24-2019, 06:03 PM   #7
Wow you guys are technical...
I just toss in whatever seens to fit close and then crank it on down and clamp the shit or spread the shit otta stuff so it fits.. just like those chopular guys do.
Old 06-24-2019, 07:13 PM   #8
Thanks for the replies all! I understand the logic of what's needed I wondered if there were some standard sizes to save me a little time!
I'm having a nightmare getting the bronze bush into the lower leg. It's interference fit to the point I've been kicking the arse out of them to get them in.. One went in other is giving me serious shit.. I've tried to find online if there's a technique but no luck. Polished it and been hitting it.. must be an easier way!! thanks again.
Old 06-24-2019, 09:35 PM   #9
All thread, nuts and washers.... duh.
Old 06-25-2019, 03:42 AM   #10
The bronze collar on the tubes has no thread sir. There's no way I should be doing what I am to the poor bushing hammering on it but I know it came out of the leg as I've seen it running! Thanks for the input though Brandt..
Old 06-25-2019, 12:00 PM   #11
They dont need threads. Slide the allthread through. Sammich a coulple washers and nuts on both sides. Turn nuts to tighten.
Wait.... you are talking about the bushings in the lower fork leg, NOT springer rocker bushings? ....never mind. You are fucked with out the tool or making one similar.
Although I did once think about trying a cam bearing install tool.
Old 06-25-2019, 01:22 PM   #12
Explains why I'm having such a shitshow of a time getting the fucker together! haha.
Old 06-26-2019, 11:01 PM   #13
Larry Ritchey
Don't know about your setup but my 2001FXDWG has spacers that are not the same dia. wide. How about centering the wheel then measure the distance from bearing to leg on both sides.
Larry Ritchey is offline   Reply With Quote
