Nitro Nostalgia - Page 3 - The Jockey Journal Board
Old 05-16-2015, 08:13 PM   #41
knuck39
Default Re: Nitro Nostalgia
incredible detail and workmanship....that is a work of art...
knuck39 is offline   Reply With Quote
Old 05-17-2015, 06:01 AM   #42
triumphrules
triumphrules's Avatar
I thought this would be hot but not as well done as yours
triumphrules is offline   Reply With Quote
Old 05-18-2015, 09:12 AM   #43
ejkelly
ejkelly's Avatar
richbob - attached is a picture I took off the internet showing PEEK piston skirt buttons. I didn't get a picture of mine before I sent them off to the builder. The other pictures are my engine components. Note that the cylinders have extra holes for better sealing and a raised edge (spigot) on the liners. The spigot passes up through the head gasket and barely touches the head when torqued. Trying to keep all the cylinder pressure inside.
Not vintage, but I did get to see John Alwine's new TF bike this weekend during testing. A very impressive machine with plenty of blower!
Name:	PEEK skirt Buttons.jpg
ID:	183002   Click image for larger version
Name:	JE Pistons.JPG
ID:	183010   Click image for larger version
Name:	Triple Rules Cyl.JPG
ID:	183026   Click image for larger version
Name:	Triple Rules Cyl2.JPG
Never trust a fart.
ejkelly is offline   Reply With Quote
Old 11-17-2015, 07:57 AM   #44
ejkelly
ejkelly's Avatar
Attached are pictures of the first completed head. The pictures also show the Ferrea valves that we're using. The valves have smaller dia stems to help with valve train weight. The valves are as large as the existing seats will allow. They also run stem seals. The head ports have been sculpted by Bill Whisenant. Additional center cylinder hold down holes, exhaust stubs and exhaust pipe spring holes are also shown. These pictures were taken at Valdosta, GA, where Bill crewed for Sam Wills.
Name:	Ferrea exhaust.JPG
ID:	199442   Click image for larger version
Name:	Ferrea intake.JPG
ID:	199450   Click image for larger version
ID:	199466   Click image for larger version
ID:	199474   Click image for larger version
ID:	199490   Click image for larger version
Never trust a fart.
Old 11-18-2015, 10:52 PM   #45
frank spittle
frank spittle's Avatar
Glad to see it is still coming along.
"Danger is real but fear is a choice" ~Nik Wallenda~
frank spittle is offline   Reply With Quote
Old 11-19-2015, 06:17 PM   #46
rigidpanman
Hey frank,this is dusterdude from dragbike.com.glad to see you're still around
rigidpanman is offline   Reply With Quote
Old 11-20-2015, 11:52 AM   #47
frank spittle
Good to hear from you.
Old 11-20-2015, 06:14 PM   #48
rigidpanman
Groovy
Old 02-19-2016, 08:10 AM   #49
ejkelly
ejkelly's Avatar
Long overdue update. Race engines are completed and being fitted back into the engine pod. The guy in the red shirt and dark hat is Bill Whisenant (Motorcycle Performance). Bill has done a lot of work on the engine pod frame mounts to allow for maintenance on the engines without having to remove the entire pod. He also strengthened the right plate to include bearing supports for the crankshaft and the parasitic loads. Slowly going back together.
I can't seem to get the last picture to upload correctly, no matter what I try. Can anyone help? Thanks.
Name:	double again2.JPG
ID:	207473   Click image for larger version
Name:	double again3.jpg
ID:	207481   Click image for larger version
Name:	double again4.JPG
Name:	double again1.JPG
Never trust a fart.
Old 03-06-2016, 11:05 AM   #50
ejkelly
ejkelly's Avatar
Rear pipes and oil system progress.
ID:	209641   Click image for larger version
ID:	209649   Click image for larger version
Name:	oil pump1.jpg
Never trust a fart.
Old 03-08-2016, 11:29 PM   #51
dandruff
dandruff's Avatar
This thread is amazing
dandruff is offline   Reply With Quote
Old 03-09-2016, 12:56 AM   #52
BobAsh
BobAsh's Avatar
Gorgeous build.
BobAsh is offline   Reply With Quote
Old 03-09-2016, 01:20 PM   #53
lippy
lippy's Avatar
I am a lurker here, now you got my attention when you said NITRO, lol. Great build. I have a question for the nitro guys here. Is running a steel rod normal in a bike engine on fuel? And it was mentioned you will be running a 50% mix. My experience has been in a car engine from 30-50% you notice a difference, from 50 -80 not so much (it can't seem to tell if its an alky or a fuel engine) then 80 and up to 98 it definitely does. If my suspicions are correct, you will be at 80% shortly. LOL. You must return a lot of fuel with a 12 gal pump. Lippy
lippy is offline   Reply With Quote
Old 03-10-2016, 07:41 AM   #54
ejkelly
ejkelly's Avatar
The fifty - fifty mixture was just a guess based on a fuel comment made by Joe Smith. The person completing the build has mentioned 70% several times, so who knows. I really don't want to blow the thing up on the first outing if it can be helped (lot of time and money in it). Tridents have been known to throw their aluminum rods at high rpms. I'm gunning for 8500 rpm. I suppose that if I break a steel rod at the rpm it will saw the cases in half instead of only making a "window." The 12 gpm pump was a recommendation from a current TF bike crew chief (they use a 15 gpm). Probably overkill for this project. Kinsler is designing and building the fuel system, full mechanical.
Never trust a fart.
Old 03-10-2016, 08:02 AM   #55
lippy
lippy's Avatar
You sure have an ambitious project that's for sure. Make sure those mags are HOT. If I may say something without offending you, find a tuner and stick with him, trust ONE, stay away from tuning opinions from everyone else. And lets get those plugs out and keep those cyls cleared !! Can't wait to hear this thing. I do understand the allure of the goddess nitro. Lippy
Old 03-10-2016, 10:15 AM   #56
ejkelly
ejkelly's Avatar
Thanks for the advice and works of encouragement Lippy. I agree, it is easy to be led down the wrong path at the track. You have a very nice digger. Here are a couple shots of a past project (alcohol only).
ID:	209817   Click image for larger version
Never trust a fart.
Old 03-11-2016, 12:32 PM   #57
lippy
lippy's Avatar
Nice Flathead! We ran a flatty for awhile also. They are expensive little buggers, Are you gonna ride that thing when it's done?
Old 03-12-2016, 09:21 AM   #58
ejkelly
ejkelly's Avatar
I'm not sure who will ride the bike lippy. I'm looking for a test pilot and if it all works well, them maybe myself.
BTW - nice flattie. I've never seen heads like those.
Never trust a fart.
Old 03-26-2016, 07:58 AM   #59
ejkelly
ejkelly's Avatar
Alright, back on track now. Here are several shots of the front exhaust being fitted. The final lengths will be determined by the length of the back set of pipes.
Name:	frnt exh mts1.jpg
ID:	211058   Click image for larger version
Name:	frnt exh mts2.jpg
ID:	211066   Click image for larger version
Name:	frnt exh mts3.jpg
Never trust a fart.
Old 04-01-2016, 02:44 PM   #60
ejkelly
ejkelly's Avatar
Oil system complete. 60 psi at idle rpm (using drill), no leaks. Each system holds about 4 quarts (including hoses).
Name:	oil pump bottom.JPG
ID:	211689   Click image for larger version
Name:	oil tanks bottom.JPG
ID:	211697   Click image for larger version
Name:	oil tanks left.JPG
Name:	oil tanks right.JPG
ID:	211713   Click image for larger version
Name:	oil tanks top.JPG
Never trust a fart.
