show & go factory PU drag build - Page 3 - The Jockey Journal Board
Old 09-25-2015, 03:56 PM   #41
fightclub
fightclub's Avatar
Default Re: show & go factory PU drag build
Moving along slowly..... opened up the sludge trap today, it was 1st time it had been open up, as all that have been down this road before , this is why you don't assume anything . Also got my generator back from a full re build . Waiting on mag rebuild and rear hub back from chromed so I can get rear tire built .
fightclub is offline   Reply With Quote
Old 09-28-2015, 07:41 AM   #42
Deucefanny
Deucefanny's Avatar
Love that drilled head. I wanted to do that to mine, but I was to scared.
The JJ, it's like having a thousand Dads!
Deucefanny is offline   Reply With Quote
Old 09-28-2015, 07:32 PM   #43
fightclub
fightclub's Avatar
Thanks Deucefanny, I can tell you someone went to great lengths to do this , the holes are very symmetrical and inline
Old 09-29-2015, 08:51 PM   #44
boxxman
boxxman's Avatar
Originally Posted by fightclub View Post
Not much to report , mag broken down, blasted , and is out for full rebuild as well as generator . crank on its way out to see if its going to even be salvageable along with cylinder and head for hone and new top end .
You rebuilding mag yourself or sending out? I'm in the same boat right now with a K2FC that i need a rebuild on, got info on a local guy here in phoenix but open to suggestions if you have experience with someone?
Build looks killer so far!
Narrow Sporty tanks, Parts and Accessories, triumph parts.
boxxman is offline   Reply With Quote
Old 10-24-2015, 11:42 PM   #45
fightclub
fightclub's Avatar
Boxxman, sorry for delay response sent you a PM . Got around to pulling sludge tube oh boy
Old 11-21-2015, 07:14 PM   #46
fightclub
fightclub's Avatar
Just got my rear rim back, 19 inch high shoulder , SS polished spokes and nipples, chromed hub. Its a slow moving project but its moving.....
Old 11-29-2015, 07:48 PM   #47
fightclub
fightclub's Avatar
Finally able to get some garage time with the holiday the last few days. I know there are a lot of different ways and easier as well to do this conversion but this is how I approached it .I didn't want to have to re chrome my JD Springer since chrome is in great shape .Also trying to keep it as stock as possible so I'm using the stock pre unit ball bearings and neck cup set up . This will allow me not have to extend the rear legs. If I used a 7/8 Timken tapered bearing kit the top cup sits much higher on top of the rigid neck and I would have had to extend the rear legs so top Springer clamp can clear top of bearing cup and then spend more $$$ re chomping. Rear legs . I also wanted to get some practice on my lathe . I machined these sleeves that I will weld to the cups and bored them to fit the 7/8 neck stem . I still will need to extend stem about 1/2 .
Old 11-29-2015, 10:31 PM   #48
flatman
nice build. looks great! is that a JD or a single/peashooter front end?
flatman is offline   Reply With Quote
Old 11-30-2015, 09:57 PM   #49
fightclub
fightclub's Avatar
thanks Flatman, its a 1929-30 JD . The lower rockers are not original ,
Old 12-02-2015, 08:44 PM   #50
graniteshins44
LOVING the look of it man. Love the JD springer and I'm digging the speed holes in the head! Badass motor mounts too.
graniteshins44 is offline   Reply With Quote
Old 12-02-2015, 09:01 PM   #51
hardrock785
Right On , ill be watching this one. English iron rocks!
hardrock785 is offline   Reply With Quote
Old 12-03-2015, 07:36 PM   #52
fightclub
fightclub's Avatar
thanks graniteshins44, don't want to do to much of a good thing though, This will be it with the speed whole details .
Old 12-03-2015, 07:51 PM   #53
oilfield money
It's been awhile , But still really dig it
Old 12-03-2015, 11:33 PM   #54
fightclub
fightclub's Avatar
yeah, its going to be a slow one oilfield money
Old 12-04-2015, 12:06 PM   #55
lilbill
lilbill's Avatar
only the british would design a motor that required pulling the crankshaft to clean the oil filter...............
RIP SwedeBobb
lilbill is offline   Reply With Quote
Old 12-04-2015, 01:02 PM   #56
I have never seen any evidence that Edward Turner was a nice man.
Old 12-17-2015, 09:12 PM   #57
fightclub
fightclub's Avatar
Just got my fully rebuilt mag back from Skip , if you need a mag or Dymo rebuilt he is great to deal with, great communication, runs a full test on mag ,lets you know what you need an don't need ,full cost breakdown before he does anything , and is very fair .If you need his contact info just PM me . Did the bright spark conversion, rewound armature , re magnetize magnets , new bearings , set end play etc.
Old 02-06-2016, 09:01 AM   #58
fightclub
fightclub's Avatar
Little more headway ,decided to change direction a little and change out the drag slick ,will still build that rim, tire combo but most likely not going to run it. I mounted up a NOS Pirelli 4.00x19 tire ,I really like the tread pattern on this tire , still fits that 60's style show bike look I'm going for .If not even more . Bolted up so empty cases , chrome time cover I picked up from Small City Cycles and the chrome engine plates that came with project .This made it 100% clear I'm going to go full show polish on engine, time to get dirty... Actually strongly considering sending it out , I would need to upgrade my buffer and get a lot more polishing gear to do the job correctly and not use all my vacation time up haha...Should have in roller very soon . My biggest struggle right now is the top rear bolt on section not being in line with back bone .For me its all about the stance of the bike , and my eye keeps getting pulled to this area , especially with the 19 being a tall tire .I'm only thinking and inch or so . Will also help me with my seat decision . I know it maybe considered sacrilegious to chop a perfect original factory rigid frame , but we shall see .
Old 02-07-2016, 12:50 PM   #59
fightclub
fightclub's Avatar
Today I opened up the gear box . No expert but don't see anything that looks out of line or mods to gear box for hill climbing ? Any feedback welcome
Old 02-09-2016, 04:43 PM   #60
rusjack
This is incredible - The stance of this on the first page got me excited, and every photo you posted up got me more and more into it. I love it!
One thing - that rebuilt mag. If someone is going to take the time to lockwire bolts, they gotta make sure to do it right! When you try to loosen one screw, it should be pulling on the lock wire to tighten the other one, and vice versa. I know its a (very) small detail, but considering this bike is FULL of small details I think you'd wanna know...
I'll keep following this one
rusjack is offline   Reply With Quote
